Thread Tools Display Modes
Old 01-11-2006, 08:55 AM   #1
reikimaster
Forum Geek
reikimaster is on a distinguished road
Default choosing a base plate ...
On my original router, a Craftsman, I made a base plate out of clear acrylic. It works great on that router for its intended purpose. I make flutes. Musical ones... hehehe... not like fluted posts. Anyways... I know the router isn't perfectly centered on the hole, but that base was never intended for using guides. I'm getting into more than flutes. Cabinet doors, beds, a sideboard... ALL things on my list of things to be made, BUT (and it's a big but) it looks like I really have to make a commitment to a specific brand of router plate. Can't mix JessEm and Rousseau and Oak Park and Rockler ... sizing issues. They don't make them a consistant size between manufacturers.
I know RouterForums has an affinity for Oak Park, but I'm wondering what (if any) advantage there is to the square plate versus the rectangular plate. That probably sounds like a really dumb question, but I currently use a clear plate and I think it's 9x11 (I'm at work, can't quite remember).
My feeling here is that I have to commit to a size or I'll be making a router table top for each different one. While not a BAD idea... I just don't have the space. I can get Rousseau plates for usually under $40. They're crowned as you know. Is that a big deal? Or I can spend more like $70 for a machined flat aluminum plate. The 11" plate from Oak Park is also in the "under $40" group but it's fixed at 1-1/2" so you wouldn't be able to swing a raised panel bit in there.
Again this is a space issue and while I know that will involve making compromises at some point, I still want to keep as many options open as I can and make whatever equipment I have as versatile as possible. My Router table, for instance, is 24" x 48". I can remove the fence, put in a blank plate, and then put a 1/4" piece of MDF on it and use it for plain old flat top workspace if I don't need the router table.
So... any thoughts on making a choice for a router plate will be helpful. It should be able to take the PC guides. The router itself in this case is a Bosch 1617. I have both the fixed and plunge bases, but will probably buy either another fixed base and take the handles off or just get the RA1164 undertable base if I can find one at a nice price and it looks like I can.
Thanks in advance!
-- Charlie
reikimaster is offline   Top - Reply with Quote
Old 01-11-2006, 10:22 AM   #2
jerrymayfield
Forum Geek
Woodpecker(woodpeck.com) has a phenolic plate that comes with 3 inserts -1"-3" and one for PC guide bushings,comes with a brass starter (safety) pin for $49.95. This may meet your needs. They are a good company to deal with.
Good Luck
Jerry
Old 01-11-2006, 01:07 PM   #3
reikimaster
Forum Geek
wow... I had been on their web site a while back, but forgot how I found it. I think the TLR Phenolic is just what I'm looking for AND it can come pre-drilled for the Bosch 1617.
I can get the plate, template, and the suggested bit for under $85. And I think their plate is actually just a tad bigger than the clear plate I have so I *could* possibly just expand the current recess OR I might be able to flip the table over and make another recess OR (and this is probably what I'll do) I could just go out and get another 2 slabs of 24x48x3/4 MDF and glue up another top.
thanks!
Old 01-12-2006, 09:08 PM   #4
presumed_druid
Forum Fanatic
presumed_druid's Avatar
presumed_druid is on a distinguished road
Not really an answer for you here, Reiki. More like another question....
Has anyone tried the round (9" diameter) base-plate from Lee Valley that slips into the table from the under-side? If so, what do you think of it?
It looks pretty good to me, and I'm considering ordering one up. The base-plate accepts one and three quarter inch guides and inserts (as is the Veritas standard), and can be left on the router to be used free-hand. I only have one router, and switching between table and free routing .... hmmmph!
presumed_druid is offline   Top - Reply with Quote
Old 01-13-2006, 09:41 AM   #5
jerrymayfield
Forum Geek
I haven't used their router plate or table,but I have purchased many of their products and have never been disappointed.
Regards
Jerry
Old 01-13-2006, 10:37 PM   #6
MrZ
New Member
MrZ is on a distinguished road
I use the Woodpecker plate & I'm very happy with it. Very well made. Plate even has leveling screws in case your opening isn't perfect.
MrZ is offline   Top - Reply with Quote
Making your own sub base plate Mike Guide Bushings and Templates 9 08-18-2008 09:43 PM
Base Plate for Ryobi Router... Drog822 Portable Routing 3 06-10-2007 09:23 PM
Finding the correct base plate Mossy Oak General Routing 2 12-14-2005 06:40 AM
Centering Base Plate -Sam- General Routing 15 01-04-2005 10:15 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109
