Table-mounted Routing Discussions solely based on operations that are using the table-mounted router. Bob and Rick say "More than 90% of all operations using the router can be done with the table-mounted router.
Thread Tools Display Modes
Old 09-27-2004, 01:04 PM   #1
shrogers
New Member
shrogers is on a distinguished road
Question Sticky slide without the springs.
I own a Porter Cable router bought in a combo kit with interchangeable fixed and plunge bases. I removed the springs from the plunge base, but the motor still does not slide easily. When I try to raise it from underneath, the base plate pops out of the table because it sticks. Does anyone have an idea how to deal with this. I am hesitant to apply any lubricant for fear of it attracting dust.
Shannon
shrogers is offline   Top - Reply with Quote
Old 09-27-2004, 03:31 PM   #2
reible
Supreme Forum King
reible's Avatar
Shannon
Check out this thread:
www.routerforums.com/showthread.php?t=134
This might or might not have anything to do with your issue, I happen to use a paste wax and have never seen sawdust stick to it, more details on the thread.
Ed
Old 09-29-2004, 01:26 PM   #3
shrogers
New Member
Default Paste Wax
Ed,
I am not familar with paste wax. Is this the same thing used on cars or perhaps the waterproofing agent rubbed into hiking boots. Lend me some insight please. Plus where do it get some?
Shannon
Ed[/quote]
Old 09-29-2004, 02:33 PM   #4
NewMontanaWorkshop
Forum Geek
NewMontanaWorkshop's Avatar
NewMontanaWorkshop will become famous soon enough
I had a stick of "Oldham CUT-Ease" stick lubricant that I used on the slides of my sticky plunge base. Picked it up at the local Home Depot.
Seemed to work quite well.
NewMontanaWorkshop is offline   Top - Reply with Quote
Old 09-29-2004, 02:56 PM   #5
ejant
Router King
Supreme Forum King
ejant's Avatar
ejant will become famous soon enough
Paste wax is car wax as well as floor wax in paste form.
To protect my table saw I use Collonite Wax, it is a boat wax and highly durable.
Ed,
Shannon
Ed
[/quote]
ejant is offline   Top - Reply with Quote
Old 09-29-2004, 03:19 PM   #6
reible
Supreme Forum King
reible's Avatar
Ed,
Shannon
Ed
[/quote]
The stuff I use is TREWAX clear and has Carnuba wax in it. They say it is a "floor care" product, "no paraffin or greasy solvants". This one pound can has been with me for a while, sorry I don't recall if I got it a wordworking place or hardware store.
I use it on the table saw, jointer, planer, router table, and many other things to protect and lub the surfaces.
I use a car wax that has carnauba in it as well but have never tried the one from the car...... well except on the car. Maybe some one else has???????
Ed
Old 09-29-2004, 03:39 PM   #7
shrogers
New Member
Default Thanks...
Thanks everyone, very helpful. I'll hit "The Depot" tonight and pick something up.
Old 10-02-2004, 10:05 PM   #8
DONALD
Sr. Member
DONALD is on a distinguished road
SHROGERS.......... I don't know which model you have but can you tell me how you got the left spring out. I have a 690 and the springs seem much stronger than they need to be. Thank you............DON
DONALD is offline   Top - Reply with Quote
Old 10-06-2004, 11:32 PM   #9
reible
Supreme Forum King
reible's Avatar
Shannon
Did you find something at Home Depot to fix the problem or does it still stick?
Ed
Old 10-07-2004, 01:12 PM   #10
John R. Fortiner
John R. Fortiner is on a distinguished road
Default Sticky Plunge mechanish
Try getting a can of DRY Teflon spray and using it sparingly on the slides. This is a great non dust collecting lube. It goes on wet and dries quickly to leave a thin teflon lube behind.
John R. Fortiner
Billings, MT
PS Elmer's Slide All is one brand.
Another is Spray On's Dry TFL Lube.
John R. Fortiner is offline   Top - Reply with Quote
Removal of router springs for table use pianoman8 The Voting Booth 20 11-09-2008 11:02 AM
M12v no springs but doesn't slide easy paulcomi Table-mounted Routing 1 04-05-2007 10:22 PM
anyone pull the springs out of a Porter Cable 890 plunge base? paulcomi Tools and Woodworking 8 04-23-2006 06:26 PM
Router springs garys General Routing 4 11-02-2005 07:37 PM
Springs for M12V angus Tools and Woodworking 4 10-17-2004 06:59 AM
