| Table-mounted Routing Discussions solely based on operations that are using the table-mounted router. Bob and Rick say "More than 90% of all operations using the router can be done with the table-mounted router. |
| | #1 |
| Registered User Jr. Member | Where can I get info on router made door frames???? ![]() |
| | #2 |
| The Router Guys Forum King | cabinet doors or house doors?
__________________ Rick and Bob The Router Guys Click here to send a greeting card to friend or relative. |
| | #3 |
| Registered User Jr. Member | Cabinet doors. I m sorry I did not include this in post |
| | #4 |
| The Router Guys Forum King | I am assuming your talking about raised panel doors. If you are, you need a cope, bead and panel cutter. I will go through the process, take some photos today then post. If not please advise and we will try to help.
| | #5 |
| Registered User Jr. Member | Yes I guess that what they are called I would like to use birch panels in 1/4 ". Thanks for taking the time to show me how this is done for I am new to routers . Alsao I was wondering if the bits canbe purchased in 1/4" instead of 1/2 inch which I dont have |
| | #6 | |
| The Router Guys Forum King | Quote:
__________________ Rick and Bob The Router Guys Click here to send a greeting card to friend or relative. | |
| | #7 |
| Registered User Jr. Member | I too would like some fairly straight-forward instructions...which do you cut first the rail or stile? Some photos would be helpful. Thanks |
| | #8 |
| Router King Supreme Forum King | One imprtant thing to remember is that your wood be straight and all planed to the same thickness. Do a couple of smaller projects first to get use to the router.
__________________ |
| | #9 |
| Registered User New Member | I have made some of these doors with fair success. But I do have some problems with keeping the design smooth. I saw in a previous posting where someone advised using some kind of a feed mechanisim. Would like to know where I could get one of these and price. Garth |
| | #10 |
| Registered User Forum Fanatic | Whichever you cut 1st you need backer blocks to stop any tearout. Use a flat piece as the backer to start then when routing the ends use either a square piece or a piece cut to fill the slot on the back edge of the style or rail. This should ensure a clean finish. For the panel raising bit cut the end grain first then the next cut, with the grain, will clean it up, turn 90 degrees to do the next endgrain and so on. NEVER try to raise the panel in one go. Start with the bit low then raise it a bit after each 4 cuts til you get to the finished depth. Panel raising bits are too big for safe use in a 1/4" router. Most are 1/2" with a few at 5/16" but very few 1/4" bits. Until I get a 1/2" router I will continue raising my panels on the table saw using a jig made for the purpose.
__________________ Dewy support team at Paltalk voice chat program |
| Kitchen cabinet make over (new doors / drawers) | Nickbee | Show N' Tell | 11 | 11-13-2008 06:26 PM |
| Oak draw fronts and cabinet doors | vapochilled | Show N' Tell | 12 | 01-17-2008 02:06 PM |
| Faux Cabinet Doors | WoodyRon | Tools and Woodworking | 2 | 08-03-2007 07:56 PM |
| arched rail cabinet doors | jimf | Introductions | 1 | 02-12-2006 12:41 PM |
| kitchen cabinet doors help | puretrick | Tools and Woodworking | 15 | 06-05-2005 05:28 PM |
