| Table-mounted Routing Discussions solely based on operations that are using the table-mounted router. Bob and Rick say "More than 90% of all operations using the router can be done with the table-mounted router. |
| | #1 |
| Registered User | Since the welcome message stated that there are no dumb questions, I will ask. When do you remove the fence and use the safety pin? |
| | #2 |
| Registered User Forum Geek | Hi: The fence is removed when you are going to use a template and a cutter with a bearing guide to route material in other than a straight line. The safety pin is used to provide a solid point to allow the template and material to be cut to get to the bearing and the cutter. If not used the cutter would have a tendency to pull the template, the material, and possibly your hand through the bit. Hope this helps, Woodnut65 |
| | #3 |
| Marine Engineer Forum King | well said woodnut, I'd also like to add that making a quick and dirty bit guard is well worth the effort when working away from the fence. There are a bunch of good books available from your library on router use and safety, all with easy safety devices and jigs. Search the forum topics for 'books' and get some titles. Happy routing
| Is workshop safety needed? | Check twice! | Shop Safety | 18 | 07-12-2008 11:27 PM |
| DC Question | angus | Lobby | 3 | 03-31-2008 08:29 PM |
| Half Blind Router Template Question | stevek433 | Introductions | 4 | 03-01-2008 12:17 PM |
| Safety Question | beers_4 | Shop Safety | 4 | 01-29-2007 07:02 PM |
| What price do you put on safety? | kp91 | General Routing | 13 | 01-08-2006 09:15 PM |
