| Table-mounted Routing Discussions solely based on operations that are using the table-mounted router. Bob and Rick say "More than 90% of all operations using the router can be done with the table-mounted router. |
| | #1 |
| Registered User New Member | Hi, went to my first wood show yesterday..Man o man my head is still spinning with all that neat stuff that i think, i need, to do the job right. ![]() I bought a wood set for putting hard wood on the edge of plywood.I seen Bob use a birds mouth bit, I think. the folks at the show helped me to buy a bit that is supposed to touch 90% of the glue surface. They said it is a new bit that they make.the bit was at the Freud place but its not a freud. The plywood bit has a bearing on it ,when I lined up the bearing flush with the fence and took my 3/4 ply through it ,It dug in so much that there was a 1/16 to 1/8 gap on the other side of the fence between the work and the fence.. I didnt even try the hard wood bit because i dont think i am doing something right.. THE profile of the bit is square in the center and angles out to the edges.. Does any body know what this bit is called and How do I use it???????? thanks ![]() |
| | #2 |
| The Router Guys Forum King | Can we have a picture, drawing or maybe a link to a website showing the router bit.
__________________ Rick and Bob The Router Guys Click here to send a greeting card to friend or relative. |
| | #3 |
| Marine Engineer Forum King | Does the set look like these? http://pricecutter.com/product.asp_Q_pn_E_P16-4040 It sounds like the you need to set the bit further into the fence so that it lines up with the max depth of your cut (not the bearing), or you need to shim the outfeed fence out a bit to support the stock,and work it like you would when edge joining stock. If you run it the way it is you'll have a lot of snipe on the ends of your stock, and have to cut it off. Practice for a while in some cheap stuff like MDF until you figure out what works best.
| | #4 |
| Registered User New Member | Doug, Yes, that was the bit the 60 degree bit set. http://pricecutter.com/product.asp_Q_pn_E_P16-4040 I guess the bearing was made for ... I dont know why the bearing is on the ply bit but not the hard wood bit . I dont think I would have bought this bit if it takes this long to set up. I am trying to KISS . Keep IT Simped Stupid mind set. I want to have more fun and enjoyment doing wood working than wasting wood. I will try it some more and see if its worth it. Thanks for the help. Keith Prov.27:17 ![]() |
| | #5 | |
| Forum Contributer Supreme Forum King | Just one more link for the bit set. http://www.mlcswoodworking.com Part # 5432,5433,7732,7733 1/4" and 1/2" Shanks $39.00 and $44.95 with free shipping the norm. With a bearning on the male bit(s) I have both 1/2" shank sets (60deg. and 90deg.) and the setup is a bit tricky but once you have it set your good to go, I cut the male 1st and then cut it down to size on the table saw.( 3/4" to 7/8" thick the norm.) the bits are 1" high. I also use two router tables for this bit setup,just incase I screw up one of the parts cutting the 45deg.ends or run short on oak the banding. "I cut them 3 times and it's still to short" hahahahaha Have a good one. Bj Quote:
| Pattern Glue | BernieW | Wood Scrolling | 14 | 09-25-2008 11:16 PM |
| To glue or not to glue | AxlMyk | Project Plans and How To | 3 | 05-04-2008 11:41 AM |
| Glue advice | Router is still my name | Tools and Woodworking | 17 | 10-08-2006 11:18 AM |
| Glue | berry | The Finishing Touch | 3 | 01-21-2006 11:46 AM |
