| Table-mounted Routing Discussions solely based on operations that are using the table-mounted router. Bob and Rick say "More than 90% of all operations using the router can be done with the table-mounted router. |
| | #1 |
| Registered User Forum Geek | Wow. I just installed my Woodpecker plate into my exising table (I flipped the top over). I wish I had done this from the beginning, but there was that money thing... Anyways. It went so well that now I'd like to build another table top. I'd laminate the next one and here's a question... Do you do anything special to the contact cement before laminating? It appears from what I'be been reading that you are basically just laminating formica (or formica-like) material from Lowes or Home Depot onto whatever substrate you used (mine is MDF). Do you thin the contact cement first or just use it straight? AND... Do you route your recess before or after laminating? |
| | #2 |
| Registered User Forum Geek | Make sure both surfaces a very clean, I have not usually found it necessary to thin solvent based contact cement. after appling cement to both surfaces allow it to almost dry (tack-up) put something between the surfaces to keep them apart -dowels.sticks etc.put the plastic laminate on the dowels and then remove the dowels(one at a time). You will definately need a heavy duty roller to work the laminate. It sounds more complicated than it is. Regards Jerry |
| No questions in this section! | Mark | Router Reference | 0 | 06-08-2008 01:59 AM |
| Couple Questions for an Oak Park Top Expert | Mike in CA | Table-mounted Routing | 1 | 04-06-2007 04:38 PM |
| So I am considering making my own table, a couple of questions... | Cowinacape | Table-mounted Routing | 16 | 03-30-2007 11:57 AM |
| Crossword Puzzle with BJ's questions | BobandRick | RouterForums.com News & Feedback | 0 | 02-01-2007 02:16 PM |
| Some general observations and questions about routers and bits | mftha | Tools and Woodworking | 8 | 09-03-2006 07:47 PM |
