| Table-mounted Routing Discussions solely based on operations that are using the table-mounted router. Bob and Rick say "More than 90% of all operations using the router can be done with the table-mounted router. |
| | #1 |
| Registered User New Member | Hi everybody. I'm new on the forum, I just bought a Benchdog ProTop Contractor table and a Porter Cable 892, a set of bushings and a Jasper insert with bushing sized ring. I set everything up and to my dismay I found the bushing isn't centered. I assumed the rings and screw holes would have been machined accurately and the alignment would be perfect. Will I need to elongate the screw holes that attach the router or is there a better way? |
| | #2 |
| Marine Engineer Forum King | sometimes my plate will shift as I tighten the screws down. I get around this by tightening the screws with the centering pin and guide chucked up in the router. you might be able to just give your baseplate a "tap" and shift it enough to center things up.
| | #3 |
| Registered User New Member | Thanks, I'll give that a try but it seems like the flat head screws will want to put it back where it was when I retighten them. |
| | #4 |
| Official Greeter Supreme Forum King Join Date: Sep 2004 Location: New Lebanon, Ohio "USA" First Name: Dave or "Doc" Posts: 4,678 ![]() | Welcome to the forums banjopicks. Also, good luck with your PC 892. Dave the "Doctor"
__________________ Dave the "Doctor" In woodworking there is no scrap, only firewood. ![]() Please edit your profile with a name and location so we can better assist you and make for a friendlier forum. |
| | #5 | |
Let me understand what problem you are having.... you purchased a router and then attached it to a jasper mounting plate, the mounting plate was designed for the router and you followed the instuctions to mount it but the router is not centered to the mounting plate... right? Before you start doing any modifications... When you do as was suggested on a previous post using the centering jig did that fix it? If not it could be that the part is defective, a call to the Jasper people should be the next step if things are still wrong. You paid for it to be done right so don't mess with it as then you will not be able to return it... or it could be they have a trick or two that might help out. If you are determined to make modifications I can give you some hints on what to do but first check with them. Ed | |
| Freud FT1700 Router and Guide Bushings | dwwilson44 | Guide Bushings and Templates | 7 | 08-21-2008 09:49 PM |
| Guide bushings for skil 1825 | rick112563 | Guide Bushings and Templates | 1 | 05-05-2008 10:19 AM |
| need something to use guide bushings on! Help Please!! | unlimitedwoodworker | Guide Bushings and Templates | 8 | 11-15-2007 04:42 PM |
| Guide bushings on the cheap | routerman1969 | Guide Bushings and Templates | 14 | 07-01-2007 10:25 AM |
| Guide bushings | saltysteele | Tools and Woodworking | 0 | 04-22-2005 04:37 PM |
