Table-mounted Routing Discussions solely based on operations that are using the table-mounted router. Bob and Rick say "More than 90% of all operations using the router can be done with the table-mounted router.
Thread Tools Display Modes
Old 03-31-2006, 12:37 PM   #1
Butch Ellis
New Member
Butch Ellis is on a distinguished road
Default Router Bit moving
I was running some stock through my table router the other day and all of a sudden it got harder so I stopped the router and pulled the material out. I found that my router bit had been slowly coming up (coming out of the collet). I retighten the bit and started again to the same avail. I then tried a new bit and it did the same. Do I now have to replace my whole router, the collet, ???
Butch Ellis is offline   Top - Reply with Quote
Old 03-31-2006, 02:45 PM   #2
Gilbear
Supreme Forum King
Gilbear's Avatar
Gilbear is on a distinguished road
Don't see why you'd have to replace the whole router if everything else seems OK. Are you sure it's the bit moving or is the depth setting slipping? If the bit itself is slipping, clean the inside of the collett well - may just be sawdust keeping it from tightening up firmly on the bit - also wondering how much material you're trying to cut in one pass. You might want to back off and give it another try. At any rate, you should be able to replace the collett without a big cash outlay. Couple of thoughts off the cuff anyway.
Gilbear is offline   Top - Reply with Quote
Old 03-31-2006, 07:11 PM   #3
Dr.Zook
Supreme Forum King
Dr.Zook's Avatar
First Name: Dave or "Doc"
Dr.Zook is on a distinguished road
Send a message via Skype™ to Dr.Zook
Butch, something else. Make sure you are not bottoming out the bit in the router. Sometimes , if you bottom out the bit, it will seem tight, but when you start to cut it will loosen.
Dave
the "Doctor"
Dr.Zook is offline   Top - Reply with Quote
Old 04-03-2006, 07:09 PM   #4
Butch Ellis
New Member
Gilbear. Thank you I will try replacing tjhe collect and cleaning out the router,
and I will try taking less depth cuts. Butch Ellis
Mixing Bosch 1617 Router fixed base with Craftsman professional router sf_basilix Starting Off 5 01-21-2008 09:54 AM
Motorized Router Lift - Eagle Lake Style johnwnixon Table-mounted Routing 10 09-13-2007 07:59 AM
New Router my way reible General Routing 14 06-10-2006 11:19 PM
