| Table-mounted Routing Discussions solely based on operations that are using the table-mounted router. Bob and Rick say "More than 90% of all operations using the router can be done with the table-mounted router. |
| | #1 |
| Registered User Jr. Member | If I was going to start a dado for a cabinet door frame and start it 2 "from the end of the stile is there a way to set a start block like a stop block??I would use a 1/4 " straight bit for the dado. My stiles are 23 and 28 inches long and routertable is only 24 inches over al lenght so it is only 12 inches from cutter to end of table. I was thinking of drilling pilot holes on either end and drop the bit in the hole and the mark on the fence where the end of the cut will end up so I dont run it to the end of the work. ![]() |
| | #2 |
| Registered User Dedicated Member | You could also mark the edges of your bit on the fence then mark the start and stop on the work piece.As you lower the work piece you will have to adjust the start line on the piece to the outside line for your bit.If you have never used this method you might want to pratice on a piece of scrap first. Good luck
__________________ JH |
| | #3 |
| Registered User Sr. Member | I did that once and drilled pilot holes where the dado starts and finishes. It worked really well too!! The only thing is to make sure that the pilot holes match the diametre of the router bit. I didn't match them up well enough and the finishing hole wasn't as clean as I would have liked but it wasn't going to be seen so what the hey!!
__________________ The speed of light travels faster than the speed of sound, that's why people appear intelligent until they open their mouth ... |
| | #4 |
| Registered User Jr. Member | Oh yes there is a good pile of scrap wood at the table.Thanks alot |
| | #5 |
| Registered User Jr. Member | Thanks for the the tip. Like I told John H there is a good supply of scrap wood and then from there I burn it in my wood stove in the shop |
| | #6 |
| Registered User Member | I've done it using two holes and it didn't work out to well for me, I have had better luck drilling just a hole at the beginning point and marking a stop pleace
__________________ Vaughn "Brad" Bradley |
| | #7 |
| Registered User Jr. Member | What I did today was I centered a mark on fence then drew line on work put fence in front of my work so it was locked into the router fence.I raised the work just enough to set it down where the dado was to start and marked the back of work .I ran it till the mark was centerd on the back of work and had perfect dados |
| | #8 | |
Ed | |
| | #9 |
| Registered User Jr. Member | You know I did not do that however I will look into it and be safe.Thanks again Ed for the help and vital info on saftey |
| Router Table Dado Jig | RoyBullets | Jigs and Fixtures | 11 | 06-16-2008 09:41 PM |
| Dado Jig for Plunge Router | bobj3 | Jigs and Fixtures | 19 | 10-31-2006 12:57 AM |
| FREUD Dado Sets | sawstop | Tools and Woodworking | 4 | 10-30-2006 04:57 PM |
| Router Adjustable Dado Jig | Barry_White | Jigs and Fixtures | 4 | 02-07-2005 02:17 AM |
| Dado blades and other table saw specialties | Mike | Tools and Woodworking | 3 | 01-05-2005 09:07 PM |
