Table-mounted Routing Discussions solely based on operations that are using the table-mounted router. Bob and Rick say "More than 90% of all operations using the router can be done with the table-mounted router.
Thread Tools Display Modes
Old 04-18-2006, 08:31 AM   #11
Gilbear
Supreme Forum King
Gilbear's Avatar
Gilbear is on a distinguished road
Originally Posted by Jens Jensen
I noticed that some have bearing on bottom of shank some on top what is with this
If you're working in a table, the bearing on the top of the shank is mostly what you'd use - if out of the table, with the pattern on top of the workpiece, the bearing at the bottom of the shank is what you'd use. It just simply gives you the flexability to follow or mimic a finish edge that's either above or below the piece you're shaping.
Gilbear is offline   Top - Reply with Quote
Pattern Glue BernieW Wood Scrolling 14 09-25-2008 11:16 PM
E-Z link heart pattern jsoika Table-mounted Routing 1 06-24-2007 07:25 PM
pattern routing JJ101 General Routing 2 04-15-2006 07:00 AM
Best bit for pattern cutting? NewMontanaWorkshop Table-mounted Routing 8 06-06-2005 03:45 PM
Pattern routing curves kak047 Jigs and Fixtures 6 11-03-2004 03:31 AM
