| Table-mounted Routing Discussions solely based on operations that are using the table-mounted router. Bob and Rick say "More than 90% of all operations using the router can be done with the table-mounted router. |
| | #1 |
| Registered User New Member | I have some bed legs that are cut with a slight radius and want to know how I do this with a table router. What do I need and whatever else |
| | #2 |
| Registered User Forum Geek | Can you be a little more specific? There are lots of talented hobbyists here. Help is not far away. -Derek |
| | #3 |
| Senior Moderator Supreme Forum King | Jen, normally you would make a pattern out of Masonite(hardboard) that is 1/4" thick and attach it with double sided carpet tape. Rough cut your wood to be close to the pattern. Use a bit that has a roller bearing on it to follow the pattern and make your final shape. This method will require very little sanding.
| | #4 |
| Forum Contributer Supreme Forum King | Jen Just to add to Mikes post. A pattern (template) is the best way to make more than one item of the same pattern. Here's a list of bits that you can use to do this with. From: http://www.grizzly.com Super Duty bits (Pattern bits ) C1306z,C1308z,C1309z,C1310z Super Duty bits (Shear Cuts bits) C1352z,1354z Ind.Quality bits (Pattern bits ) C1306,C1307,C1308,C1309,C1310 Ind.Quality bits (Shear Cuts bits) C1353,C1354 The Shear bits will give you a clean cut "require very little sanding" like Mike said. Once you make a template you can use it over and over to make as many as you need. You can also use SMALL nails to hold the template to the new blank, the double sided tape is not cheap and nails are but you must take care not to drive them to deep. You can also use a brass guide in the router base plate when you are cutting thick stock. (3/4 " or more ) and using a template (Pattern) use a 1/2" router bit and a brass guide. see Grizzly items H3134 and C1012, and C1699 at http://www.grizzly.com Hope this helps Bj ![]() |
| | #5 |
| Forum Contributer Supreme Forum King | Add On Just to fix part numbers ![]() New parts numbers below Super Duty bits (Shear Cuts bits) C1353z,C1354z http://www.grizzly.com Bj ![]() |
| | #6 |
| Forum Contributer Supreme Forum King | I should post a note about Grizzly part number H3134 TEMPLATE GUIDE kit You can get one from Harbor Freight that's at a lower price. see below ▼ 10 PC. SOLID BRASS TEMPLATE GUIDE KIT ITEM 37402-2VGA $19.99 Sale price below $15.99 http://www.harborfreight.com/cpi/cta...emnumber=37402 Bj ![]() |
| | #7 | |
| Registered User Jr. Member | Quote:
| | #8 |
| Registered User Jr. Member | I noticed that some have bearing on bottom of shank some on top what is with this |
| | #9 |
| Registered User Forum Geek | That bearing follows the pattern that you want to duplicate. Only the edge of the cutter will shape the stock. In one of your other requests, the guys responded with details on how to make a pattern or jig. If you can get Bob and Rick's show on PBS- Router Workshop, it will become clear. -Derek |
| | #10 |
| Forum Contributer Supreme Forum King | Jen Just to add to Derek post. If you don't get the Router Workshop on your PBS TV station you can now see it on the NET ( 24 /7 ) http://www.thewoodworkingchannel.com/ SCHEDULE Search the schedule to find out when your favorite show will air next (note all times are EST) 4/16/2006 2:00 AM The Router Workshop Jewelry and Lingerie Chest, Part 1 4/16/2006 2:30 AM The Router Workshop Jewelry and Lingerie Chest, Part 2 4/16/2006 3:00 AM The Router Workshop Jewelry and Lingerie Chest, Part 3 4/16/2006 3:30 AM The Router Workshop Jewelry and Lingerie Chest, Part 4 Bj ![]() |
| Pattern Glue | BernieW | Wood Scrolling | 14 | 09-25-2008 11:16 PM |
| E-Z link heart pattern | jsoika | Table-mounted Routing | 1 | 06-24-2007 07:25 PM |
| pattern routing | JJ101 | General Routing | 2 | 04-15-2006 07:00 AM |
| Best bit for pattern cutting? | NewMontanaWorkshop | Table-mounted Routing | 8 | 06-06-2005 03:45 PM |
| Pattern routing curves | kak047 | Jigs and Fixtures | 6 | 11-03-2004 03:31 AM |
