| Table-mounted Routing Discussions solely based on operations that are using the table-mounted router. Bob and Rick say "More than 90% of all operations using the router can be done with the table-mounted router. |
| | #1 |
| Registered User Sr. Member | Hi all, I plan to make a new router table to hold my new 3.25 hp hulk. A while back I built a router table to attach to my Delta contractors saw. I made a square template to cut the hole. Then I cut a piece of clear plastic and rounded the corners. It was kind of a pain to get a good fit. What's the best way to cut a hole and then match a plate to fit? Thanks, Deck |
| | #2 |
| Forum Contributer Supreme Forum King | Deck I'm doing the same thing,you may want to get a top that's done ![]() The top must be true and flat to work right. The one I just got you can change the bits from the top of the router table or pop it out quick and easy the router boys way ( Bob & Rick ) The neat thing about this top you can use it from the front side or the back side of the cabinet. If you want to see a snapshot just ask and I will post one. Top from: http://www.sommerfeldtools.com/products.asp?ID=6 http://www.sommerfeldtools.com/ ------------------------- Plus the one that's Mike's talking about.▼ BUT note***The only plate molded with a slight crown to insure the cutter is the highest point for accurate, distortion free cuts. http://froogle.google.com/froogle?q=...Search+Froogle Bj ![]()
__________________ PodCast videos RWS on YouTube http://www.routerforums.com/86898-post1.html Besure and click on the Up Arrow key ▲ on the Youtube video, you can select other youtube videos on router tables ![]() http://www.woodworkingonline.com/?s=dovetail Machine Cut ▼ http://www.woodworkingonline.com/200...cut-dovetails/ http://www.woodworkingonline.com/woo...podcast-store/ http://www.woodshopdemos.com/menu2.htm Bob J. Last edited by bobj3; 06-12-2006 at 10:33 AM. |
| | #3 |
| Forum Contributer Supreme Forum King | Deck Mounting the P.C. router can be a bit tricky because the mount holes come out right on the side of the Alum.snap out ring. Marc said to just notch the Alum.ring I didn't like that ideal so I took a forrest bit and put in a pocket down to the base of the Alum.ring seat and then drilled it out and put in a counter sink holes under the snap out ring. I used a 1/16" bit to start off with and the used a 3/16" drill bit for the mount screws. Just a NOTE*** the screws to hold the PC in place are 10-24 (3/16-24) Take some 10-24 set screws that are 1" long put them in your drill and grind them to a sharp POINT then screw them into the base of the router. Then put in the 1 9/16" plug you made with the old 1/4" router bit,glued in place. Then place the router on the botton side of the base plate and TAP the router base with a hammer, this will mark the spot to drill the 1/16" holes to mount the router to the base plate. After you have the 1/16" holes turn over the base plate a use a 3/8" forrest bit to put in the pocket holes then drill the holes out to 3/16" and counter sink the holes. You will need a 3/8" OD max counter sink bit. Just some snapshots for kicks... Bj ![]()
__________________ PodCast videos RWS on YouTube http://www.routerforums.com/86898-post1.html Besure and click on the Up Arrow key ▲ on the Youtube video, you can select other youtube videos on router tables ![]() http://www.woodworkingonline.com/?s=dovetail Machine Cut ▼ http://www.woodworkingonline.com/200...cut-dovetails/ http://www.woodworkingonline.com/woo...podcast-store/ http://www.woodshopdemos.com/menu2.htm Bob J. Last edited by bobj3; 06-12-2006 at 12:18 PM. |
| | #4 |
| Senior Moderator Supreme Forum King | Another possibility is to go with a Rousseau mounting plate. You can purchase a template kit which makes a perfect fit every time. There is also centering/mounting kits to assure your router is perfectly mounted in your plate.
