Table-mounted Routing Discussions solely based on operations that are using the table-mounted router. Bob and Rick say "More than 90% of all operations using the router can be done with the table-mounted router.
Thread Tools Display Modes
Old 06-19-2006, 04:02 PM   #1
simplenik
Forum Geek
simplenik is on a distinguished road
Default Circular saw guide
Good day
The “circular saw guide” idea is very old, I just “modified” it by using “floor panels”.
Those panels are made of HDF covered from both sides with plastic laminate (Formica), which is very smooth and the saw is “skiing” on it, and if I have 15 years guaranty, they should be good.
The panels are coming in 50” or 100” length (I use the 50”).
The width is 7-1/2” and the thickness is 5/16”.
I connected 2 panels to get the required width (they “click” to each other nicely).
When you cut the width, cut it wider than the “motor line” to be able to clamp it without interference between the motor and the clamps.
You can glue anti-skid tape or sanding paper at the bottom, personally, I don’t like it.
The measuring and guide positioning method gives a very precise cut.
niki
simplenik is offline   Top - Reply with Quote
Old 06-29-2006, 10:05 PM   #2
deck99
Sr. Member
deck99 is on a distinguished road
simplenik,
Do you have photos? I want to build a circ guide too. I am not sure what floor panels you are talking about.
Thanks,
Deck
deck99 is offline   Top - Reply with Quote
Template Guide sizes mftha Guide Bushings and Templates 11 06-04-2008 06:35 PM
Circular Saw and router guide "Off-set" plate simplenik Tools and Woodworking 9 11-19-2007 11:20 AM
Guide bushing identification Mike Guide Bushings and Templates 26 03-24-2007 10:57 PM
Porter-Cable template guide no where to be found jnam Jigs and Fixtures 3 02-21-2006 08:15 AM
Guide bush for portercable 517 TomB Portable Routing 7 03-20-2005 12:40 PM
