Thread Tools Display Modes
Old 07-07-2006, 11:17 AM   #1
LBrandt
Member
LBrandt is on a distinguished road
Default Question about raised panel router bits
Hello,
Please excuse my ignorance, since I'm still a newbie when it comes to routing. I have a Bosch RA1171 router table, and I'm still in the process of choosing a router for it. I'd like to someday be able to do raised panels with it, and I know that to do it best, I'll need a 3+ HP router for it.
My dumb question is, what is the difference between a vertical raised panel bit and a horizontal raised panel bit, and what do forum members mean when they talk about a horizontal router table versus a vertical router table?
Isn't a standard router table like mine, a horizontal router table, since the table top is parallel to the floor? What would a vertical router table be?
Louis
LBrandt is offline   Top - Reply with Quote
Old 07-07-2006, 12:39 PM   #2
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Louis
"what is the difference between a vertical raised panel bit and a horizontal raised panel bit"
The vertical bit ,is just that the cutters are vertical for the most part and the horizontal are just that.(parallel to the top)
Real the link below and you will see a snapshot of the two types of bits in the links.
http://www.routerforums.com/showthre...?threadid=2854
With the vertical bit it takes less HP to make a panel,most 2HP can make panels some time less HP will do it also.
Now when it comes to horizontal bits ,it's true you should use a 3HP router or bigger but you can use a 2HP but it takes more cuts and more time, and every time you run the panel by the bit you take a chance of nailing the panel with a nick or low spot.
Plus the speed of the bit must come down because you are spining a big bit that will scare the hell out of you,a speed control is a must on horizontal bits.(over 200MPH)
Most of the big routers come with them.
They do make vertical router tables or you can add one to your horizontal router table.
The router is mounted on the back side of your router table (the norm) or you can add it to the side and the bit is horizontal to the table top.(parallel)
If you do a search on the forum you will find one or two of them posted.
I think del s. or Ed posted a snapshot of his if I recall.
see the link at the bottom for a snapshot of a Horizontal router Table-,they call it Horizontal .
I made one for my router table but didn't use it that much so I took it off,they are easy to make with a router base plate like Oak-Parks type and screw it to the router base and make it so it can move up or down behind the router table with pocket hole for the bit so it can drop into the table top.
They are great for many jobs like putting in mortise slots,vertical bits and alike.
Hope this helps
Bj
http://www.woodhaven.com/detail.aspx?ID=91
More snapshots below, and some new ones for me also.
http://cgi.ebay.com/WOODHAVEN-HORIZO...ayphotohosting
http://cgi.ebay.com/WOODHAVEN-HORIZO...QQcmdZViewItem
http://www.woodhaven.com/detail.aspx?ID=1252
Bj
Old 07-08-2006, 09:47 AM   #3
jerrymayfield
Forum Geek
That says it all
Regards
Jerry
Vertical Raised Panel Question rprice54 General Routing 21 07-26-2008 07:54 PM
Motorized Router Lift - Eagle Lake Style johnwnixon Table-mounted Routing 10 09-13-2007 06:59 AM
raised panel router bits Dave2 Starting Off 7 03-30-2007 10:13 AM
1/4" router and raised panel doors BrianS Table-mounted Routing 12 05-19-2006 10:06 AM
Raised Panel Router Bits Dan Butler Tools and Woodworking 3 11-20-2004 12:30 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109
