Rate This Thread - What two wrenches do you guys use?.
Thread Tools Display Modes
Old 07-31-2006, 05:13 PM   #11
kenadian
Dedicated Member
kenadian's Avatar
kenadian is on a distinguished road
Originally Posted by bobj3
You may want to look at buying the OFF SET type for routers,they go for 14.oo bucks ea.
about 3/16" thick, from 20mm to 26mm, about 7" long from the last bend.
I need a set for my M12V (21mm and 24 mm I think ), do you have a link to the offset type.
I am Kenadian!
kenadian is offline   Top - Reply with Quote
Old 07-31-2006, 05:51 PM   #12
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Kenadian
Here's just one of many,you will see it listed at the bottom of the page.
If you buy a set from sommerfeldtools besure to get the FREE video(s) it's free if you buy anything over 20.oo dollars.
You may need to call the 888-228-9268 to get both 21mm and the 24mm the one they list is for the collet nut.
Ask for Marc if he is in ,he will fix you up, I just got a Panel set and the box had a lock pin that was damage, he is shipping a FREE router box at no charge, this guy is something else,,,NICE GUY and he is the BOSS....
http://www.sommerfeldtools.com/products.asp?ID=6
Bj
Workshop Projects
Router Tables plans FREE, plus more
http://www.absolutelyfreeplans.com/W...p_projects.htm
RW Router Tip Archive
www.routerworkshop.com/router_tip_glossary.html
Floating Mortise & Tenon: A strong and Silent Joint
Old 07-31-2006, 07:19 PM   #13
Bob
Forum Moderator
Supreme Forum King
Bob's Avatar
Bob has a spectacular aura aboutBob has a spectacular aura about
Hi Kenadian
Bj
I'll have to vouch for sommerfield also. I placed my order for the 21mm offset wrench last Thursday and had it in my mailbox on Saturday. Got the free video as well
Very good folks and a quality product as well.
Bob is online now   Top - Reply with Quote
Old 08-04-2006, 09:04 AM   #14
JackW
JackW is on a distinguished road
Thumbs up Wrenches
Originally Posted by paulcomi
I picked up a second 1 1/4" porter cable stamped metal wrench, but I find the wrench pair are thin overall and they don't work as well as the wider wrench pair you guys use. I checked at a few hardware stores as well as Sears and even an auto parts store and the 1 1/4" open end wrench they sell is oftly large compared to what you seem to be using. What wrenches are you using?
I ordered a 23 mm wrench Hitachi Part Number 956922 through a local tools dealer. It is the same wrench used on the Hitachi TR12 router which preceded the Hitachi M12V router. Except for the 21 and 23 stamped in the wrench, it looks identical to the 21 mm wrench that ships with the M12V. I used clear plastic tubing on the handle of the 21 mm wrench, and black PVC tubing on the 23 mm wrench (so that the colors match the collett parts). I got the PVC tubing from a scrap piece of 7-wire cable that I used for my trailer hitch wiring. I set the wrench and the PVC out on a black surface in the hot sun to soften it before installing the PVC onto the wrench handle. For reference, the part number for the 21 mm wrench is 956923. It works fine for me, but I read somewhere that you can file off some parts and remove the collett locking plate. This will give you more clearance, but you run the risk of getting filings inside the router.
Jack
JackW is offline   Top - Reply with Quote
Old 08-04-2006, 02:49 PM   #15
kenadian
Dedicated Member
kenadian's Avatar
I emailed sommerfeld, and they no longer stock the 24mm wrench. The did however give me a link to CMT's website, but they don't have any Canadian dealers.........So I'm back to square one.
I am Kenadian!
Old 08-04-2006, 04:42 PM   #16
Billwolley
Forum Fanatic
Billwolley's Avatar
Billwolley is on a distinguished road
Paul,
I have several PC routers and therefore have several wrenches. To make everything easy (I made two sets) two wrenches together to get the thick wrenches and it makes everything very easy.
Bill
Billwolley is offline   Top - Reply with Quote
Old 05-10-2008, 11:21 PM   #17
Dave_Willemain
Jr. Member
Dave_Willemain is on a distinguished road
Arrow Router Wrenchs
Since my tool mania includes auto tools, I have always had plenty of other wrenchs around. I only use wrenchs that come the router if I am too lazy to dig out better ones. With most, I used better conventional open or flare-nut wrenches. When using bits that are smaller than the collett nut, I sometimes use a 6pt deep socket -- that is the least additional wear & tear on the nut.
[font=Georgia][size=5]Dave Willemain
Columbia, MD
DAve_Willemain@yahoo.com
Dave_Willemain is offline   Top - Reply with Quote
What do you guys think.... tpyke General Routing 2 11-16-2007 11:55 PM
I see why you guys like that big Hitachi router paulcomi General Routing 3 09-18-2006 10:06 PM
Where do the wrenches go? Joe Lyddon Table-mounted Routing 12 09-12-2006 11:43 AM
What router plate are you guys using in your videos? paulcomi Table-mounted Routing 8 06-26-2006 04:36 PM
What a pair of guys! mailee Table-mounted Routing 5 06-09-2006 11:51 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105
