| This is a discussion on How to mount the router plate... within the Table-mounted Routing forums, part of the Routers category; I finally got my router table plate from Rockler, a Bench Dog plate. There are ... |
| | #1 (permalink) | ||
| Registered User ![]() |
I finally got my router table plate from Rockler, a Bench Dog plate. There are several screws included, and I also got the router table leveling and locking hardware pack, which included 8 screws and 2 "screw in nuts"... The large screws are for screwing the router to the plate. But which screws do I use to fasten the plate to the table top? And how does the leveling screws work? There were no instructions included, so I'm a bit lost. I'm making my own router table, using a kitchen bench top. | ||
Sponsored Advertisement - Register now to remove this advertisement.
** Please be sure to read our Disclaimer at the bottom of the page. **
These advertisements are only displayed to guests, register now for your FREE account on the worlds largest router and woodworking community! |
| | #2 (permalink) | ||
The 2 black screws secure the plate to the table using the 2 opposing corner holes in the plate and screwed into the 2 anchors which you'll mount in the table. The 4 medium size screws mount the router to the 4 holes in the plate. The 3 small screws hold the center ring in place. The leveling screws will go into the table, under the plate. Your guess is as good as mine as to if they screw down or up. Best of luck!
__________________ Doug ![]() You can complain because rose bushes have thorns - or be happy that thorn bushes have roses. | ||
| | #4 (permalink) | |||
| Forum Contributor ![]() |
Hi See the More Info tab Bench Dog Router Table Plates - Rockler Woodworking Tools Here's a link you may want to check out, the guides below you can rework your new plate so you can use the guides in your router table. http://www.leevalley.com/US/wood/pag...00,51208,41778 http://www.routerforums.com/project-...-bogydave.html === Quote:
__________________ "It's fine to disagree with other members as long as you respect their opinions" MANY,MANY help files on John's web site http://legacy.woodshopdemos.com/menu2.htm Sommerfeld Tools ,Videos http://www.youtube.com/channel/UCT-n...RWaEpMA/videos Last edited by bobj3; 03-23-2012 at 11:43 PM. | |||
| | #5 (permalink) | ||
Thanks. The funny thing is that the black screws were together with the other screws on the left, while the anchors came with the leveling screws. There are actually four small screws (the three screws for fastening the insert is not in the picture). The black screws have a small head, barely enough to not slip through the holes in the plate.... | ||
| | #6 (permalink) | ||
Your link explained the anchor part, thanks. Still think the heads are a bit small though... If I tighten too hard, i think they might destoy the hole in the plate..... | ||
| | #7 (permalink) | ||
I have Woodpeckers plates, both Aluminum and Phenolic. The leveling screws went in very hard like they were cross threaded or the wrong size. There is a reason for that of course, to keep them from vibrating loose and screwing up the leveling once set.
__________________ When something is advertised as being foolproof there is always a better class of fool that comes along to prove them wrong. | ||
Sponsored Advertisements. Register to disable this advertisement.
| | #8 (permalink) | |||
__________________ John Schaben ![]() The problem with experience is I usually get it immediately after I need it. | |||
| | #9 (permalink) | ||
I'm making my own router table, so this won't be a problem I guess... | ||
| | #10 (permalink) | |||
The instruction sheet that came with my Woodpeckers plates indicated they would be hard to install or something to that effect, but didn't say why. I just surmised they were different threads because if cross threading they would have gone in at a slant which they didn't. At the same time it also made sense they were difficult to install so they wouldn't loosen and let the plate move once leveled. I don't know about other plates but my Woodpeckers plate has a spring loaded button that presses against the side of the cut out to keep it in place.
__________________ When something is advertised as being foolproof there is always a better class of fool that comes along to prove them wrong. | |||
| Router Plate Installation | Rutabagared | Project Plans and How To | 11 | 01-14-2012 07:15 PM |
| Router plate | Amalgam | General Routing | 3 | 07-10-2011 06:45 PM |
| Intro and question | john spies | Introductions | 18 | 11-04-2010 08:12 PM |
| Freud Router | stjimm | General Routing | 1 | 01-03-2009 11:04 AM |
| Hitachi M12VC Router Plate | kefjens | Table-mounted Routing | 1 | 01-02-2009 09:27 AM |
