| | #1 |
| Registered User New Member | I have a small craftsman table made for jigsaws and routers. Used it for the first time a few weeks ago with poor results. I needed to glue up a couple of boards for a book cabinet top and thought I would route the edges for a nice square face. Used a single piece fence and quickly realized the error in that thinking as my work left the infeed side of the fence...duh, that's why it came with a two piece (is it properly called a split fence?) fence. Learning curve was steep. Eventually (after 6 or 7 passes, thank goodness I was only using 2 1/2 foot stock!) I figured out to set the outfeed fence tangent to the bit and the infeed fence the depth of the desired cut...I did my best to square the two fences to one another by using the edge of the router table and a square...after jointing the two pieces, I layed them side by side the way I intended to glue them up only to find that the first and last couple of inches of each board pulled away from one another. I recut and recut taking great care to ensure square contact with both fences and got the same result time and time again. Where am I going wrong? Am I missing something fundamentally simple? Jim |
| | #2 |
| The Router Guys Forum King | After jointing the material are the edges straight? If your out on the two inches on either end might mean the router bit is exposed beyond the out-feed of the fence. check out the following tip click here to see the jointing tip
__________________ Rick and Bob The Router Guys Click here to send a greeting card to friend or relative. |
| | #3 |
| Registered User Forum Fanatic | The first thing I did after buying my table was to try jointing. I set the cutter level with the outfield side of the table and tried a few passes. The jointer fence could not have been parallel with the infeed fence as no matter how many times I tried I could not get the edge straight. This was probably as a result of the cheapish table having a number of different things on it which only paid lip service to doing what they were intended to do. I soon made my own fence which works far better than the one supplied. I also treated myself to a bench jointer to straighten boards and it was worth every penny. ![]()
__________________ Dewy support team at Paltalk voice chat program |
| | #4 | |
Ed | |
| | #5 |
| Registered User Forum Geek | Jimcrjfo: I would check the router bit to make sure it's exactly flush with the out feed portion of the fence. Also check the alignment of the infeed fence to the out feed fence by placing a straight edge across both fence halves. You sholt get the same clearance at both ends of the infeed side. Good luck, Woodnut65 |
| | #6 |
| Registered User | Do you get better results if the piece you are trying to joint is shorter than the jointing fence? Also, where should apply pressure on the stock into the fence? At the infeed side orr the outfeed side? Lou |
| | #7 | |
| The Router Guys Forum King | Quote:
__________________ Rick and Bob The Router Guys Click here to send a greeting card to friend or relative. | |
| Jointing long boards | Jtomwoods | Table-mounted Routing | 8 | 05-25-2008 09:05 PM |
| Bit for jointing question | dabeeler | Router Bits - Types and Usage | 11 | 11-13-2007 10:57 AM |
| router table jointing | dtaylor15 | Table-mounted Routing | 3 | 02-22-2006 09:21 AM |
| Router Jointing | Drick | General Routing | 1 | 12-19-2005 09:21 PM |
| Jointing alternative? | ktritz | Table-mounted Routing | 15 | 11-08-2004 03:22 PM |
