Rate This Thread - plunge or fixed base.
Thread Tools Display Modes
Old 10-22-2004, 10:05 AM   #1
bellaw
New Member
bellaw is on a distinguished road
Default plunge or fixed base
Hi guys, I'm fairly new to routing and have a question; Is it best to use a fixed base router or the plunge router for table routing? What leads me to ask this question is the fixed base part of the Ryobi RE1802M 3 piece kit worked great until problems started showing up! The locking lever wont stay locked and the highth adjusting ring became very hard to turn. I have adjusted the locking mechanisim and have taken the motor out of the housing and cleaned, polished and lubricated the highth adjusting system. This router appears to be just a POS. I repair tools of all kinds in my small repair shop but just can't seem to turn this "sow's ear into a silk purse"! I began looking at the plunge base that came with the kit and noticed a more positive locking lever and highth adjusting system, is this what I should have been using from the start? Maybe I should just scrap this cheap stuff and just go buy myself a real router! What do you recomend?.....Thanks,,,, Tom
bellaw is offline   Top - Reply with Quote
Old 10-24-2004, 01:50 PM   #2
FineHomesCarpentry
New Member
FineHomesCarpentry is on a distinguished road
Buy yourself a good quality router. I have had problems with Bosch Speed controllers letting me down. I will be going over to Dewalt.
FineHomesCarpentry is offline   Top - Reply with Quote
Old 10-24-2004, 02:54 PM   #3
Spacemanspiff
Sr. Member
Spacemanspiff is on a distinguished road
I use the DW621 in my table and have had absolutely no trouble with it. Well, maybe some trouble but that was more operator error (forgetting to lock the height adjustment on more than one occasion). I don't use a router lift or anything fancy, I just set the height once and drop it into the table. If the cut is more than recommended I set the fence up to take the first cut and just continue to move the fence back until a full cut is taken. After 4 years of doing it like this so far so good!
Hope this helps,
Aaron
The speed of light travels faster than the speed of sound, that's why people appear intelligent until they open their mouth ...
Spacemanspiff is offline   Top - Reply with Quote
Old 10-24-2004, 08:53 PM   #4
-Sam-
Forum King
-Sam-'s Avatar
-Sam- is on a distinguished road
Question
Do you mean the Bosch router itself, the speed controller on it? What do you mean letting you down? I was just curious because I hear Bosch routers are good. Later...
Boricua
-Sam- is offline   Top - Reply with Quote
Old 10-25-2004, 06:12 AM   #5
Woodnut65
Forum Geek
Woodnut65 is on a distinguished road
I prefer a plunge router for table mounting, because most fixed base routers must be
turned to adjust the hieght, which changes the position of the on/off switch.
take the springs out of the plunge router base and mount it into the table. As far as
tools made by Ryobi and Skill, I think you are right in deeming them POS.
I prefer PC, Makita, and Dewalt myself, I use these tools to make a living.
Good Luck, Woodnut65
Woodnut65 is offline   Top - Reply with Quote
Old 10-25-2004, 11:03 AM   #6
Exboss
Jr. Member
Exboss is on a distinguished road
I purchased the Porter-Cable 895PK router, plunge base plus fixed base with one motor. Using a Oak Park 11" base plate, which by the way is drilled for the router and has micro adjusting holes that align for precise above table adjustments using the fixed base and adjusting tool. This frees up the plunge base for the free hand routing chores simply by swapping motors, a mere 20 second event. I also had a Ryobi ruter and have sent it out to pasture due to the same basic defects.
Exboss is offline   Top - Reply with Quote
Old 10-25-2004, 03:16 PM   #7
JohnnyTest
New Member
JohnnyTest is on a distinguished road
I use the PC 895 and have to say it is a fine piece of machinery. I use the fixed base in the table, this gives you over the table adjustments and bit changes. Plus the horsepower is perfect for just about any job.
JohnnyTest is offline   Top - Reply with Quote
Old 10-25-2004, 09:18 PM   #8
bellaw
New Member
I really appreciate the words of wisdom from you guys, that's what these sites are for! I think I'll take the advice and get a good quality router and put this Ryobi stuff aside, maybe try to either return it to Home Depot or put it on E-Bay. I've been checking out the Dewalt 625 Plunge and will probably end up with it. I'm going to build my own kitchen cabinets and can't afford to have a tool that might let me down in the middle of a project like that! I have built a really nice router table I'll send some pictures of when I get back from vacation. Thanks again and I really like this Forum...Tom
Old 10-26-2004, 10:51 AM   #9
Putzger
Member
Putzger's Avatar
Putzger is on a distinguished road
Send a message via AIM to Putzger
There's really no doubt about it -- "scrap the crap" and "go good".
I've been seeing some Porter Cable 690 router combination kits at local Sam's Clubs for $189. (That's the motor, fixed base and plunge base set.) Those are still available at many Home Depot's as well (for a bit more).
Rockler's has been running some sales lately and has been having some reasonably good prices on the newer 890 router combination sets.
Regardless of which top brand router you do get, just be sure to go with a good one -- it's just "so worth it". Especially with what it probably the most useful of all power tools.
Steve
www.apachetrail.com/ww/
Mesa, AZ
Putzger is offline   Top - Reply with Quote
Old 10-26-2004, 07:57 PM   #10
scrollwolf
Forum Fanatic
scrollwolf's Avatar
scrollwolf is on a distinguished road
I too purchased the Poter Cable 895 PK. I had Ryobi/Craftsman before that. Stick with the Porter Cable. It is the best
scrollwolf
scrollwolf is offline   Top - Reply with Quote
Colt plunge base bobj3 Jigs and Fixtures 19 04-01-2008 07:54 PM
Craftsman Fixed and Plunge Base Combo Review..... challagan General Routing 49 01-03-2008 12:06 PM
Bosch 2.25HP Plunge & Fixed Base Router Kit 1617EVSPK jcmaro General Routing 6 01-24-2006 10:27 AM
Converting fixed base to plunge base. -Sam- Portable Routing 4 09-30-2004 03:53 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108
