Table-mounted Routing Discussions solely based on operations that are using the table-mounted router. Bob and Rick say "More than 90% of all operations using the router can be done with the table-mounted router.
Thread Tools Display Modes
Old 10-26-2004, 10:37 PM   #1
ktritz
Jr. Member
ktritz is on a distinguished road
Default Fence materials
I'm planning on building a router table for my Hitachi M12V and I was wondering what materials people suggest for the fence surface.
Do they use HDPE or UHMW-PE on the Router Workshop, and are there advantages of one over the other?
Thanks,
Kevin
ktritz is offline   Top - Reply with Quote
Old 10-27-2004, 07:08 AM   #2
Woodnut65
Forum Geek
Woodnut65 is on a distinguished road
Hi:
The Oak Park fences are Polyethelene, and they work very well. It is a stable material
and will not hurt the router bits, as you make clearance in the fence for the
bit that you may be using.
Woodnut65
Woodnut65 is offline   Top - Reply with Quote
Old 10-27-2004, 12:43 PM   #3
ktritz
Jr. Member
Hi,
Thanks for the reply. Both HDPE and UHMW-PE are type of polyethylene (high density and ultra-high molecular weight). I think UHMW is about twice the price of HDPE, but I was unsure if there are any problems with just using HDPE.
Kevin
Old 10-27-2004, 01:20 PM   #4
BobandRick
The Router Guys
Forum King
BobandRick's Avatar
I find that the HDPE is a better material to use than the Ultra High Density. It's easier to work with and will deliver the same results.
Rick and Bob
The Router Guys
Old 12-13-2004, 02:30 PM   #5
Don Hurley
Jr. Member
Don Hurley is on a distinguished road
Send a message via AIM to Don Hurley
What dimensions do you find ideal for straight fences? In thickness and width.
Don Hurley is offline   Top - Reply with Quote
Old 12-14-2004, 05:10 PM   #6
BobandRick
The Router Guys
Forum King
BobandRick's Avatar
1" thick and 2 - 2 1/2" wide...
Rick and Bob
The Router Guys
Old 12-19-2004, 07:57 PM   #7
Sidro
Member
Sidro's Avatar
Sidro is on a distinguished road
Where does one get HDPE for a fence.
Sid
Sidro is offline   Top - Reply with Quote
Old 12-20-2004, 10:19 AM   #8
cfm
Dedicated Member
cfm is on a distinguished road
OakPark.com sells prefabricated fences of the ideal HDPE material. Engineered to tight specs.
Otherwise there are a number of places on the internet that sells HDPE material.
You'll probably find the material expensive - especially when adding shipping costs etc.
All the best
cfm
cfm is offline   Top - Reply with Quote
Old 12-21-2004, 10:40 AM   #9
kp91
Forum King
kp91's Avatar
First Name: Doug
I personally find MDF faces on aluminum angle works quite well. Even without formica facing it slides pretty nicely, you can bury your bits into it and replace it economically, and if you split it down the middle, you can shim behind it and make an easy jointer fence.
Before I have used a jointed 4x4, scraps of hardwood scewed to my tablesaw fence, you name it it works. My favorite feature of the router workshop is that they can turn out quality items without a $400 fence or a $300 router lift. Simple really works.
1 John 1:9
Old 12-23-2004, 06:15 PM   #10
cfm
Dedicated Member
Sid
I guess your question was not answered fully:
Here are two:
http://www.usplastic.com/
http://www.mcmaster.com/
and I am sure there are others.
All the best.
cfm
CMT Industrio Router Table System (orange cabinet) Ladd Table-mounted Routing 50 02-06-2008 12:34 PM
Questions about Table Saw fence tmiller Starting Off 4 04-02-2007 09:05 AM
Homemade router fence g-man Jigs and Fixtures 11 06-05-2006 01:33 PM
Face Lift for the Router Fence bobj3 Jigs and Fixtures 7 06-05-2006 09:57 AM
Some Thoughts on Fence Control Gilbear Table-mounted Routing 5 12-20-2005 06:38 PM
