Table-mounted Routing Discussions solely based on operations that are using the table-mounted router. Bob and Rick say "More than 90% of all operations using the router can be done with the table-mounted router.
Thread Tools Display Modes
Old 12-16-2006, 01:56 PM   #1
beemerbob
Member
beemerbob is on a distinguished road
Default Routing Plywood Edges
For economical reasons I made several adjustable bookends for Christmas presents. I was satisfied with the overall appearance, but I had to do some serious sanding to get rid of router tearout.
I realize that I am routing edge grain. There are probably some good ideas on how to use a 1/2 inch roundover bit and reduce the end grain tear out on 1/2 inch Baltic Birch Ply. Can anyone help?
Bob from Northwest Florida
beemerbob is offline   Top - Reply with Quote
Old 12-16-2006, 05:04 PM   #2
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Bob
You can give this a try it works for me, I made a quick and easy jig out of some hardwood and put it a NEW utility blade that is screw (in two spots) to the stock and just hangs down a bit from the bottom of the sled jig.
You just press down and drag it down the stock and it cuts the plywood about a .010" deep right at the edge of the round over ,the bit cleans the blade cut right up but it's real hard to see the blade cut once you sand the stock a bit.
You can also make more than one or two passes with the SHARP router bit but plywood just likes to rip out.
nasty stuff sometimes )
Bj
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Routing Plywood kmdsouza General Routing 8 03-30-2007 12:32 PM
Advanced (?) Template Routing billdcon Jigs and Fixtures 6 03-09-2005 01:07 PM
routing curved edges on a router table John B General Routing 3 01-14-2005 11:50 AM
Routing edge on plywood Dimitri Guest General Routing 2 10-20-2004 03:34 PM
