Table-mounted Routing Discussions solely based on operations that are using the table-mounted router. Bob and Rick say "More than 90% of all operations using the router can be done with the table-mounted router.
Thread Tools Display Modes
Old 12-29-2006, 08:28 AM   #1
boxer
Supreme Forum King
boxer's Avatar
boxer is on a distinguished road
Default enough power?
Will a 2-1/4HP router have enough power for vertical crown molding bit? I'm wanting to make some picture frames.
Thanks, Boxer
boxer is offline   Top - Reply with Quote
Old 12-29-2006, 10:33 AM   #2
kp91
Forum King
kp91's Avatar
First Name: Doug
I would think so. I can use a horizontal panel raiser on mine, just don't overload it. If necessary, you can shim your fence so it nibbles away instead of trying to take the whole cut at once. Adding shims to your fence instead of moving it for each cut keeps your final dimension constant.
1 John 1:9
Old 12-29-2006, 11:27 AM   #3
Senior Moderator
Supreme Forum King
Mike has disabled reputation
I would tend to agree with Doug. I know my Bosch 1617's have enough power for this job. As with any situation where you are removing a large amount of material do it in multiple passes.
Old 12-29-2006, 11:38 AM   #4
Charles M
Forum Fanatic
Charles M's Avatar
Charles M is on a distinguished road
Boxer,
Check the router's user's manual for maximum bit diameter and cut length for your router. I can't speak for other brands, but the Freud FT1700 2-1/4HP router will run our new wide crown molding bits with no problem. We cut the bulk of the profile in one or two passes and make a final light pass to remove the ripples.
Charles M
Freud America, Inc.
Charles M is offline   Top - Reply with Quote
Old 12-29-2006, 12:07 PM   #5
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Boxer
I have 4 vertical crown molding bits that I use all the time and I use a
P.C. 1 3/4HP and it works just fine, I do make one pass then make one more to get a nice clean cut.
Boxer here's a tip, the bit below works great for making picture frames,you may want to check it out.
Picture Frame Rabbet Bits
2 flute, carbide tipped bits with totally enclosed ball bearings.
Designed for making custom picture frames or mirrors. The double stepped rabbet will cut either a 1/8" x 3/8" or 1/4" x 3/8" rabbet for your glass or mirror, and an additional 3/8" x 3/8" rabbet for your artwork and backing board. Use for 1” or larger stock.
http://www.mlcswoodworking.com/shops.../bt_pictr.html
Just one more tip Boxer
You will see a snapshot (see Below) of a quick and easy jig to make that will let your moldings come out true and clean.
The key to this jig is the Push Block, it will keep your fingers back out of the way and keep the stock true to the fence.
Just make one pass on all the stock then reset the fence and the support fence and your done.
You may need to set the out feed fence out by just a bit (1/32") the norm because some of the moding bits will remove the edge off the stock when you make the pass,that's when the jig comes in handy.
Bj
enough-power-molding.jpg  enough-power-panel_bits.jpg  enough-power-picture_frame_bit.jpg  enough-power-picture-frame-jig.jpg  enough-power-molding1.jpg
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Rockler Safety Power Tool Switch 1/3 off Ladd The Bargain Bin 3 12-16-2007 04:45 PM
Most hated power tool in the shop. Router is still my name Lobby 5 09-16-2006 08:04 AM
power supply/extension cord questions rprice54 Tools and Woodworking 10 06-28-2006 05:31 PM
Power tools and vibration Mike Tools and Woodworking 5 01-14-2005 12:36 PM
Looking to purchase a power planer Bob Tools and Woodworking 12 12-26-2004 11:15 PM
