| Table-mounted Routing Discussions solely based on operations that are using the table-mounted router. Bob and Rick say "More than 90% of all operations using the router can be done with the table-mounted router. |
| | #1 |
| Registered User Dedicated Member | How do you put the spline slot in a 45 Degree miter? I can do it with a table saw but would rather use a router table. BB
__________________ Bruce in the Peg |
| | #2 |
| Forum Contributer Supreme Forum King | Hi Bruce You can do it with a table saw but it can be tricky and not to safe. You can do it on the router table with a quick jig and it will come out clean and true. Use a slot cutter and the jig. see a snapshot of the jig below. To make the spines clean and true use a T & G set and remove the bearing from the center of the bit set and put in some small OD washers (5/16" ID and 3/8" OD) that add up to 1/4" thick spacer, or made one with some 1/4" thick plastic. Make a pass then take it to the table saw and cut off the spline strips. The spines will be about 3/4" wide and a true 1/4" thick. ![]() Note*** make a test cut b/4 you make the splines you may need to add a washer to the spacer because the carb tips hang down just a bit. Bruce, have a look see at the jigs below for a 45deg. spline You can use a slot cutter to do this job also. ![]() You can do one at a time or as a pair, the pair way is the best ,it will line up both parts at the same time for the spline. ![]() The 4th, snapshot is for a standard bit (1/4" or 3/8" the norm.) http://www.routerforums.com/jigs-fix...ghlight=spline For the LONG spline below (snapshots) Bj ![]()
__________________ PodCast videos RWS on YouTube http://www.routerforums.com/86898-post1.html Besure and click on the Up Arrow key ▲ on the Youtube video, you can select other youtube videos on router tables ![]() http://www.woodworkingonline.com/?s=dovetail Machine Cut ▼ http://www.woodworkingonline.com/200...cut-dovetails/ http://www.woodworkingonline.com/woo...podcast-store/ http://www.woodshopdemos.com/menu2.htm Bob J. Last edited by bobj3; 01-11-2007 at 04:22 PM. |
| | #3 |
| Retired Moderator Supreme Forum King | Another neat jig BJ! Corey |
| | #4 | |
| Registered User Forum King | Quote:
Tom | |
| | #5 | |
| Forum Contributer Supreme Forum King | Quote:
Thanks Corey Did you see the one for the miter and if so what do you think ? Bj ![]()
| | #6 | |
Tom | |
| Anyone use/have the Kehoe Dovetail Spline Jig? | thewoodennewfie | Jigs and Fixtures | 32 | Yesterday 12:07 AM |
| Spline vs. Tongue & groove | wanart | General Routing | 1 | 02-28-2006 07:22 AM |
| Slot Cutter or Spline cutter | kimbert | General Routing | 3 | 10-20-2005 07:26 PM |
| butterfly spline | scottc | General Routing | 3 | 08-07-2005 10:34 PM |
| dovetail spline joints | reible | Jigs and Fixtures | 7 | 10-02-2004 02:50 PM |
