| Table-mounted Routing Discussions solely based on operations that are using the table-mounted router. Bob and Rick say "More than 90% of all operations using the router can be done with the table-mounted router. |
| | #1 |
| Registered User New Member | Howdy All, My dust collection (DC) system splits going into my router table. One hose goes to the fence, the other to the router surround. (FYI, this is the Norm Abram’s router table.) Despite my DC system, when I route a dado on my router table, the sawdust shoots out the dado slot and all over the shop. Of course that's because the DC through the fence is useless when routing a dado. Works great for a rabbit or other edge routing. If I was routing a lot of dadoes, I would duct tape my shop vac in position to suck up some of the sawdust, very inefficient, I still had to clean up the shop. I decided to test an idea. In line with the router collet, just to the left of the router plate, I used a 3/4" straight bit and plunge routed a 1-1/4" hole through the table top into the router surround. It worked. Almost all of the sawdust was pulled down that hole, into the router surround, and into the DC system. The sawdust that did not get collected was from between the time I started the dado until the dado covered the hole. Even some of that got sucked up. Kent |
| | #2 |
| Forum Contributer Supreme Forum King | Hi Kent This also works ▼Bj ![]()
__________________ PodCast videos RWS on YouTube http://www.routerforums.com/86898-post1.html Besure and click on the Up Arrow key ▲ on the Youtube video, you can select other youtube videos on router tables ![]() http://www.woodworkingonline.com/?s=dovetail Machine Cut ▼ http://www.woodworkingonline.com/200...cut-dovetails/ http://www.woodworkingonline.com/woo...podcast-store/ http://www.woodshopdemos.com/menu2.htm Bob J. Last edited by bobj3; 01-10-2007 at 05:08 PM. |
| | #3 |
| Registered User Dedicated Member | BJ, As usual, I have a question on your drawing. The vac plate and hose slide fore and aft in paralell with the direction of workpiece. (right?) OK then, what makes the chips go around the workpiece and into the vac? Where is the bit in your drawing? Bruce in the Peg
__________________ Bruce in the Peg |
| | #4 |
| Forum Contributer Supreme Forum King | Hi Bruce Take a look at the 2nd. snapshot, that should help. ![]() Bj ![]()
| Practacle Dust control for "part timers" | bob oswin | Tools and Woodworking | 34 | 07-31-2008 08:26 PM |
| dust extraction for craftsman routers | mjmpropman | General Routing | 0 | 04-23-2008 12:11 PM |
| Dust question | Qstick | Tools and Woodworking | 37 | 03-05-2007 04:46 PM |
| Table saw Dust Collection Guard | angus | Tools and Woodworking | 13 | 03-20-2006 08:02 PM |
| Big time dust problem | lnagel | Table-mounted Routing | 4 | 07-22-2005 07:11 AM |
