Table-mounted Routing Discussions solely based on operations that are using the table-mounted router. Bob and Rick say "More than 90% of all operations using the router can be done with the table-mounted router.
Thread Tools Display Modes
Old 01-17-2007, 11:39 PM   #1
pottsgo
New Member
pottsgo is on a distinguished road
Default Milwaukee 5615 Aluminum Table Plate Help
Hi All,
I have my Milwaukee 5615 router mounted to a table using a homemade polycarbonate table insert. I'd like to upgrade the plate to an aluminum version to fix some sagging issues. However, I'm having trouble determining which aluminum plates will work with this router with regards to the bolt hole pattern. It appears most of the aluminum plates on the market don't specify the hole patter dimensions. Instead they're advertised for fitting mostly Porter & Cable routers but I don't know which P&C model # matches the Milwaukee model on the hole pattern. I've taken my circular router base plate to the local Woodcraft store but the only aluminum plates there have about 20 holes in them to match every pattern available! I'd like to avoid that!
So anyway - if anyone has other routers (P&C in particular) that have a 3 hole pattern where the holes are ~2 3/8" from the center then please let me know.
Thanks!!
Greg
pottsgo is offline   Top - Reply with Quote
Old 01-17-2007, 11:56 PM   #2
Senior Moderator
Supreme Forum King
Mike has disabled reputation
Greg, you can make your own plate. Aluminum is easy to drill and shape. Check your phone book or online for a metal supplier. Transfer the holes from your current plate, center punch and drill. This is easy to do and you will take pride telling others you built your own.
Old 01-18-2007, 12:25 AM   #3
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Greg
Just drill the holes in the Alum. plate to fit your router
You will need to made a quick jig to get the router on dead center of the plate.
Like the one in the snapshot below, once you have the jig made, then find 3 screws that are the same size to hold the router to the base plate(black part) ,remove the heads and grind the screws to a sharp point then hand screw them into the base, then chuck up the jig and set it into place on the new Alum. plate,tap the screws with a hammer (with care ) this will mark the point you will need to drill the new mounting holes in the Alum. plate (use a 1/8" bit 1st) and then counter sink the holes and then drill them out to the right size on the top side of the new plate..
To grind the screws down to a sharp point, just use your battery drill with the screws chucked up and use the belt sander or grinder.
Bj
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 01-18-2007, 11:10 PM   #4
pottsgo
New Member
Thanks for the advice guys. I hadn't heard of anyone making their own aluminum base plates so it didn't even occur to me to try.
thanks again,
Greg
Old 01-19-2007, 12:29 AM   #5
lrr
Sr. Member
lrr's Avatar
lrr is on a distinguished road
You can get a "blank" plate from Rockler, so you can drill your own holes. Plus, you will be able to change inserts -- it includes one with a large opening, and one with no opening so you can cut it yourself.
http://www.rockler.com/product.cfm?O...Select=Details
Also available is an extra large plate. Check out their website for more options if you are hesitant to make one. Finally, if you want to go wild, one of the "lifts" may work -- I looked at your router on Google, and saw it out of its mount. If it is ~ 3" to 3.5" in diameter, then one of the lifts that clamp around the motor would be a great way to go. Maybe you could contact Rockler to see if that would be an option.
I've got their standard table, and very happy with it. I'm thinking of getting a second plate just so I can swap out different routers easily.
Lee
lrr is offline   Top - Reply with Quote
Old 01-19-2007, 01:02 AM   #6
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Greg
Just some more to look at
http://www.woodpeck.com/aluminsert.html
http://www.woodpeck.com/blankphenolicinsert.html
http://www.woodpeck.com/inserts.html
Bj
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
need advice for inserting rosseau router plate into bench dog promax cast iron table sf_basilix Table-mounted Routing 7 02-21-2008 07:00 PM
Insert Plate size and 11.5" handle spread; how to prevent problems Ladd Table-mounted Routing 34 12-14-2007 02:08 PM
mounting table plate to router dthompson Table-mounted Routing 13 12-05-2007 04:05 PM
Bosch Router Table Plate Pattern Rhino Starting Off 2 11-24-2007 08:35 PM
Need help with Rockler Aluminum table plate hitnailonhead Table-mounted Routing 8 11-24-2007 01:30 PM
