Table-mounted Routing Discussions solely based on operations that are using the table-mounted router. Bob and Rick say "More than 90% of all operations using the router can be done with the table-mounted router.
Thread Tools Display Modes
Old 01-22-2007, 01:53 AM   #1
sameerallidina@shaw.ca
New Member
sameerallidina@shaw.ca is on a distinguished road
Default Rail & Stile Dilemna
Well guys, I'm stumped.
I have been trying to match the profile of some rail and stile joints in existing cabinetry that I have. The profile isn't doesn't quite match any of the "standard" matching rail and stile sets. Has anyone seen anything like this or have an idea of how to create such a cut? I have attached a picture with dimensions, the material is 3/4" of an inch thick.
Ideally all I need is a "large diameter" 1/4 cove bit, or an upside down cove bit.
Thanks for any info.
sameerallidina@shaw.ca is offline   Top - Reply with Quote
Old 01-22-2007, 02:30 AM   #2
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Sam
It looks like it was done with a Shaper cutter, the key is the 5/8" deep(slot) cut.
They are made for 1 3/8" to 1 1/2" thick stock,but they will work on 3/4" thick stock some comm. wood shops just use one type of cutter for all the doors they make.
It looks like the items below but they make many types just like the ones that fit in routers with a 1/2" shank, But the norm is 3/8" to 7/16" deep slot on most of the R & S sets.
You can some times get around this by using the R & S sets WITHOUT the bearings and just use the fence as the guide but it will take a pass or two to get it right on the button (5/8" deep on both parts)
Note***the bearings on most R & S sets is a spacer as well so to say if you remove the bearing you will need to put in a spacer, sometimes the lock collar on some router bits works fine for this but the set screw must be down inside all the way or to say flush or you can use/get AN/NAS/MS flat washers.
C2172 Entry Doors 6 pc. Stile & Rail Set - Quarter Round, 3/4" Bore
http://www.grizzly.com/products/c2172
http://www.grizzly.com/products/c2175
http://www.grizzly.com/products/cate...spx?key=162300
http://www.grizzly.com/catalog/2007/Main/514
Bj
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 01-22-2007, 02:07 PM   #3
New Member
Bob,
Thanks for the quick reply... this really helps, I know where to look now. I was completely stumped.
Old 01-22-2007, 03:49 PM   #4
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
You'er Welcome Sam
Hope you get it done
Bj
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Hi all -- rail and stile bit and 1/2" collet help! Bryan Introductions 14 11-26-2007 12:40 AM
Stile & Rail Bit DougO Router Bits - Types and Usage 7 07-11-2007 09:42 PM
Rail & Stile 1/4" shank? Drugstore Cowboy Router Bits - Types and Usage 5 05-24-2007 12:14 AM
Rail and Stile alignment....HELP arkwood Router Bits - Types and Usage 8 01-10-2007 12:07 PM
Stile and Rail setup? fitz Jigs and Fixtures 1 03-26-2005 08:53 AM
