Help
Adjusting Router Speed.
This is a discussion on Adjusting Router Speed. within the Table-mounted Routing forums, part of the Routers category; Hello People, I was wondering. Can you put a Dimmer switch in line to a ...
Old 01-28-2007, 07:03 PM   #1 (permalink)
Charger1966 is on a distinguished road
Default Adjusting Router Speed.
Report Post Report This Post!
Hello People, I was wondering. Can you put a Dimmer switch in line to a receptacle. Then plug a non variable speed router in that receptacle and use the dimmer as a speed controller. I was kicking this idea back and forth and thought why not put it on the forum.
Keep making sawdust
Lance.
Charger1966 is offline
Old 01-28-2007, 07:20 PM   #2 (permalink)
bobj3's Avatar
bobj3 has much to be proud ofbobj3 has much to be proud ofbobj3 has much to be proud ofbobj3 has much to be proud of
Hi Lance
In short No,,,sorry,,, but you can get one at the right price from ▼
at about the same price as a light dimmer.
http://www.harborfreight.com/cpi/cta...emnumber=43060
see pdf file below how to use the device on your router.
http://www.mlcswoodworking.com/shops.../speedcon.html
http://www.grizzly.com/products/G3703
http://www.grizzly.com/products/g3555
Bj
MLCS Instruction Pages & Videos
plus FREE MLCS Project Plans
http://www.mlcswoodworking.com/shops.../instruct.html
Part Finder
find parts for your power tools
http://www.ereplacementparts.com/
Need some help replacing the parts
http://forums.ereplacementparts.com/
Many Router Tips from RWS
http://www.routerworkshop.com/router_tip_glossary.html
http://www.routerforums.com/email-ro...-members-only/
Router Tables ,Ready to use
http://www.rt1000.com/
http://rt1000.com/_wsn/page2.html
Bob J.
bobj3 is online now
Old 01-29-2007, 06:13 AM   #3 (permalink)
Cassandra's Avatar
First Name: Cassandra
Cassandra is on a distinguished road
Keep making sawdust
Lance.
Hi Lance:
The usual dimmer module that is sold in stores for use with house lighting is usually rate something like 300 Watts incandescent load. 300 Watts at 120 Volts is only 2-1/2 amps. Most, if not all, routers are well beyond the 2-1/2 amps rating. As indicated by Bob, you will need a module that is rated for higher currents.
Cassie
(electrical engineer)
Cassandra is offline
Old 01-29-2007, 08:15 AM   #4 (permalink)
Mike will become famous soon enough
Exactly to the point Cassie. Which brings up the fact that 3+ HP routers may or may not need a larger speed controller than the HF unit which is rated at 15 amps.(This is because manufacturers take liberties with their ratings) There are 20 amp speed controllers available but they do cost quite a bit more. Always go by the rating tag on your router.
Old 02-03-2007, 06:13 PM   #5 (permalink)
Lee Brubaker is on a distinguished road
Like vacuums router hp is peak hp. Namely, the manufacturer has put the router on a bench dynometer & then has applied load until that router is screeching & smoking to get the peak hp rating. You will notice that most routers come with a 15amp cord, & if you have never blown a circuit breaker then you have come nowhere near the peak hp claimed by the manufacturer. By contrast induction motors are rated for continuous hp. Namely it will deliver the stated hp running all day long.
Lee
Lee Brubaker is offline
Old 02-04-2007, 07:33 AM   #6 (permalink)
Thanks for the great info. I bought a speed Contoler from Rockler and it works great.
Keep Making that Sawdust.
Lance
Old 10-24-2009, 02:18 PM   #7 (permalink)
First Name: Ian
Ianelm1930 is on a distinguished road
Hi Lane,
I have a fixed speed router, a Makita 3600B, which runs at 22,000 rpm.
I want to use a lock mitre cutter at a recommended speed of 16,000 rpm
I realise it is two years ago since your post re a Rockler speed contoller. Have you any experience of otaining one in UK?
Regards, Ian
Ianelm1930 is offline
Old 10-24-2009, 03:09 PM   #8 (permalink)
jschaben is on a distinguished road
Talking
Ian, try the UK ebay site or any of your resident woodworking suppliers.
John Schaben
"I haven't failed, I have simply discovered several hundred ways that don't work"
jschaben is online now
Old 10-26-2009, 06:14 AM   #9 (permalink)
Hello Ian, Sorry no I have not had the pleasure of buying in the UK. Hope that you find on. I bought mine from Rockler.
Lance
Old 10-31-2009, 03:36 PM   #10 (permalink)
First Name: Ian
After further advice folks, I have ordered a DeWalt 625 variable speed router to prevent nasties happening!
Was this agood choice?
Ian
New Router my way reible General Routing 16 03-13-2010 05:25 PM
Mixing Bosch 1617 Router fixed base with Craftsman professional router sf_basilix Starting Off 10 10-24-2009 05:34 PM
Motorized Router Lift - Eagle Lake Style johnwnixon Table-mounted Routing 10 09-13-2007 06:59 AM
