| This is a discussion on Rousseau Base Plate mounting within the Table-mounted Routing forums, part of the Routers category; I bought this base plate and am in the process of mounting it in a ... |
| | #1 (permalink) | ||
| Forum Contributor ![]() |
I bought this base plate and am in the process of mounting it in a new 3/4" MDF tabletop.. Using the Rousseau template, I've gotten the hole routed out, and am working on the rabbet.. I'm to the point where 3 corners are flush, and one where the plate is a little high.. Questions: 1. Do many of you rout the rabbet a bit deep, and then install the adjusting screws? Seems like the only solution.. 2. How the heck do you get the center rings out of the plate?
__________________ . Never, under any circumstances, combine a sleeping pill and a laxative on the same night. Mike - Retired FoMoCo Tradesman My Gallery @ http://www.routerforums.com/axlmyks-stuff/ | ||
Sponsored Advertisement - Register now to remove this advertisement.
** Please be sure to read our Disclaimer at the bottom of the page. **
These advertisements are only displayed to guests, register now for your FREE account on the worlds largest router and woodworking community! |
| | #2 (permalink) | ||
| Forum Liaison ![]() |
Mike, if you followed the instructions for setting the bit depth the entire plate should sit a hair below the table surface. The leveling screws are adjusted to bring it flush. You may need to make your cut a hair deeper. Remember when you are adjusting the level to use your straight edge at diagonals over the corners, not across the center which is slightly higher. The rings simply snap apart. They are very snug from the factory, you may need to smack them with a mallet the first few times.
__________________ Mike "Living in the D" (this means Detroit!) "It's fine to disagree with other members as long as you respect their opinions" | ||
| | #4 (permalink) | ||
Mission accomplished.. Now to mount the router to it..
| | #5 (permalink) | ||
| Registered User ![]() |
Just read where you could use a new pencil with eraser and tap the center ring out,made sense to me. | ||
| | #6 (permalink) | ||
Billy, some of the plates (when new) are so tight you need a mallet the first time you remove the rings. After that they snap in and out like they are supposed to.
| Making your own sub base plate | Mike | Guide Bushings and Templates | 63 | 01-09-2013 05:24 PM |
| Rousseau 3509 9" x 12" x 3/8" Deluxe Router Base Plate | deck99 | Table-mounted Routing | 14 | 01-20-2007 11:31 AM |
| choosing a base plate ... | reikimaster | Table-mounted Routing | 5 | 01-13-2006 10:37 PM |
| Centering Base Plate | -Sam- | General Routing | 15 | 01-04-2005 10:15 AM |
