| Table-mounted Routing Discussions solely based on operations that are using the table-mounted router. Bob and Rick say "More than 90% of all operations using the router can be done with the table-mounted router. |
| | #11 |
| Senior Moderator Supreme Forum King | The link worked last night. Lets try this again. http://www.sears.com/sr/javasr/produ...seBVCookie=Yes
| | #12 |
| Forum Contributer Supreme Forum King | Looks like this maybe the way to go ▼ http://www.sears.com/sr/javasr/produ...cemldffidflk.0 Plunge + Fixed base for 110.oo bucks, Variable speed,Soft start,almost a PC setup for about 1/2 the price. ----------- Variable speed, heavy-duty, permanently lubricated 100 percent ball bearing motor delivers 12,000-25,000 rpm. Soft start permits the motor rpm to slowly increase to the desired speed setting. Three integrated work lights clearly illuminate the work surface. Die-cast aluminum motor housing adds strength while limiting and reducing vibration. Choose either the standard fixed base or dual-arm plunge base with depth gauge, turret stop and machined arms for smooth up/downward motion which plunges up to 2-3/16 inches. Each base features large, clear, 6-11/16 in. sub-base with square edge on the plunge. Oversized debris shield and vacuum shield provide a clear sightline to the bit. Spindle lock allows for easy bit exchanges. Live tool indicator lights up when power connected. Router includes 1/4 iin. and 1/2 in. collets, edge guide, bit wrench, operators manual and storage case. Wt. 9.5 lbs. NOTE *** Catalog/Online Exclusive If I didn't have so many routers I would like to send off for one. ![]() --------------------- UPDATE 10:28AM 2/10/07 I said the heck with it and I sent off for one ,,, I love routers and this one looks like a great deal ,can't wait to give it a test run . ![]() I will post a review once I run it down a board or two... CAN'T HAVE TOO MANY ROUTERS ![]() Bj ![]()
__________________ PodCast videos RWS on YouTube http://www.routerforums.com/86898-post1.html Besure and click on the Up Arrow key ▲ on the Youtube video, you can select other youtube videos on router tables ![]() http://www.woodworkingonline.com/?s=dovetail Machine Cut ▼ http://www.woodworkingonline.com/200...cut-dovetails/ http://www.woodworkingonline.com/woo...podcast-store/ http://www.woodshopdemos.com/menu2.htm Bob J. Last edited by bobj3; 02-10-2007 at 02:58 PM. |
| | #13 |
| Senior Moderator Supreme Forum King | BJ, the LED's and power indicator light made me stop and think. Is this a Ridgid clone?
__________________ Mike Please edit your profile with a name and location so we can better assist you. Last edited by Mike; 02-10-2007 at 12:43 PM. |
| | #14 |
| Forum Contributer Supreme Forum King | Hi Mike "Ridgid clone?" Hard to say but I will know in about week or less ![]() If it is it's a real bad copy ![]() Note the plunge base is not the same,the handles are the same,the adjustment/lock for the plunge is not the same,it's not the same in many other parts as well .It looks more like a PC the way the motor slips into the base (guide pins/gear rack) Bj ![]()
__________________ PodCast videos RWS on YouTube http://www.routerforums.com/86898-post1.html Besure and click on the Up Arrow key ▲ on the Youtube video, you can select other youtube videos on router tables ![]() http://www.woodworkingonline.com/?s=dovetail Machine Cut ▼ http://www.woodworkingonline.com/200...cut-dovetails/ http://www.woodworkingonline.com/woo...podcast-store/ http://www.woodshopdemos.com/menu2.htm Bob J. Last edited by bobj3; 02-10-2007 at 09:27 PM. |
| | #15 |
| Registered User Forum Fanatic | The link works.. However your must search for routers... The model I have is not listed, but they do have it as a combo for $109.00 (plus some cents) They also have 1 3/4 model listed. They sure look like 892.
__________________ The Geezer |
| | #16 |
| Senior Moderator Supreme Forum King | Trap, please check the photo I added to my last post. I am almost positive this model is built by Ridgid.
| | #17 | |
| Forum Contributer Supreme Forum King | Hi Mike "Three integrated work lights clearly illuminate the work surface" do you know if it's the same on the Ridgid ?? Bj Quote:
__________________ PodCast videos RWS on YouTube http://www.routerforums.com/86898-post1.html Besure and click on the Up Arrow key ▲ on the Youtube video, you can select other youtube videos on router tables ![]() http://www.woodworkingonline.com/?s=dovetail Machine Cut ▼ http://www.woodworkingonline.com/200...cut-dovetails/ http://www.woodworkingonline.com/woo...podcast-store/ http://www.woodshopdemos.com/menu2.htm Bob J. Last edited by bobj3; 02-10-2007 at 03:49 PM. | |
| | #18 |
| Retired Moderator Supreme Forum King | Ridgid's are made my ITT...otherwise known as the parent company of Ryobi, Ridgid and as of a year or so ago.... Milwaukee. They are well known to make lots of stuff for Craftsman. Given that, they don't look the same to me. Corey |
| | #19 |
| Registered User Jr. Member | Don't know if this will help, but kinda looks like an old Black-decker/DeWalt base router I had. It had the same rack and gear assy to adj height. |
| | #20 | |
I think Bj buys routers like I buy clamps..
__________________ Mike - Retired FoMoCo Tradesman My Gallery @ http://www.routerforums.com/axlmyks-stuff/ | |
| Router for routing table | fredtrumble | Table-mounted Routing | 1 | 12-09-2007 08:53 PM |
| From Table Routing To A Shaper | cabinetman | Table-mounted Routing | 6 | 06-13-2007 08:21 PM |
| Table Routing Direction | berry | Table-mounted Routing | 4 | 01-03-2006 07:48 PM |
| Table routing | template tom | Table-mounted Routing | 1 | 11-10-2005 02:57 PM |
| routing curved edges on a router table | John B | General Routing | 3 | 01-14-2005 11:50 AM |
