Help
Model 320.17542 and table routing
This is a discussion on Model 320.17542 and table routing within the Table-mounted Routing forums, part of the Routers category; Craftman has a two hp, 11 amp, variable speed, router with a base that uses ...
LinkBack (1) Thread Tools Display Modes
Old 02-06-2007, 02:49 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
trap's Avatar
First Name: Ed
trap is a name known to alltrap is a name known to all
Default Model 320.17542 and table routing
Report Post Report This Post!
Craftman has a two hp, 11 amp, variable speed, router with a base that uses porter/cable type bushings.
What makes this THE cheap router for table mounting is... it is adjustable with a 3/16 allen wrench through that table top. Yes a built in router lift.
Unlock it, adjust it, lock it. I have it mounted in a Rousseau router base plate. Cost: $69.95 plus tax.....regular 79.95.......But I used a sears credit card..10.00 off. After they ring it up PAY THE CREDIT CARD OFF
This is NOT a plungle router, so no springs to remove.
The Geezer
trap is offline
Old 02-07-2007, 07:30 AM   #2 (permalink)
trap's Avatar
First Name: Ed
Here is is photos of router
The Geezer
trap is offline
Old 02-07-2007, 09:28 AM   #3 (permalink)
bobj3's Avatar
bobj3 has much to be proud ofbobj3 has much to be proud ofbobj3 has much to be proud ofbobj3 has much to be proud of
Hi Trap
Nice looking router ,what did you pay for the router ? is that the 70.oo bucks or was the for the plate ?
It looks like a neat router for the router table what is the size of the Allen key to adjust it from the top side ?,do you use a long T type Allen key ? or a standard Allen wrench .
Bj
MLCS Instruction Pages & Videos
plus FREE MLCS Project Plans
http://www.mlcswoodworking.com/shops.../instruct.html
Part Finder
find parts for your power tools
http://www.ereplacementparts.com/
Need some help replacing the parts
http://forums.ereplacementparts.com/
Many Router Tips from RWS
http://www.routerworkshop.com/router_tip_glossary.html
http://www.routerforums.com/email-ro...-members-only/
Router Tables ,Ready to use
http://www.rt1000.com/
http://rt1000.com/_wsn/page2.html
Bob J.
Old 02-07-2007, 10:07 AM   #4 (permalink)
kp91's Avatar
First Name: Doug
The fixed base kind of looks like the porter cable 890 series or a Bosch setup, with the lock lever and then the worm gear driven from above the table. Who is making this series of routers? any guesses?
1 John 1:9
http://instaverse.com/
kp91 is online now
Old 02-07-2007, 10:10 AM   #5 (permalink)
bobj3's Avatar
Hi Doug
I'm thinking Porter Cable/Black & Decker . (lock lever maybe the give away and the base plate can take on the PC brass/steel guides )
Bj
Part Finder
Bob J.
Old 02-07-2007, 11:30 AM   #6 (permalink)
Mike will become famous soon enough
This looks very much like the 893PK I examined at Lowe's. The black rack is a big clue, the clear sub base plate another. I will rule out Bosch for sure. Trap, please look very carefully at the sub base plate. Does it fit smoothly to the router base all the way around? The PC I examined had a gap of about .020" a third of the way around!
Old 02-07-2007, 12:38 PM   #7 (permalink)
trap's Avatar
First Name: Ed
It looks like an 892........The price 195.99, this model is 2 1/4 hp sears is a 2 hp
I paided 69.99 (did not give the correct price in post.) That is for the router.
The Base plate is the same size as the router.
I have never seen a craftsmen with a base plate that would fit PC guides.
The Geezer is not known as a man who spends money for fancy things. I am using a 3/16th four inch long hex key.
Bud
The Geezer
trap is offline
Old 02-09-2007, 10:59 PM   #8 (permalink)
Oakery is on a distinguished road
I cannot find this model number on the Sear's website... did you buy it in-store? Also, can you include a pic of the spec plate on the tool?
Thanks,
Oakery
Oakery is offline
Old 02-10-2007, 04:15 AM   #9 (permalink)
Oakery, Sears is a real bother with their part and model numbers. This is the same router: http://www.sears.com/sr/javasr/produ...TOOL&ihtoken=1
Trap bought this for $10 off because he used a Sears card.
Old 02-10-2007, 07:41 AM   #10 (permalink)
AxlMyk's Avatar
AxlMyk is a name known to allAxlMyk is a name known to all
Linky no worky..
AxlMyk is offline
LinkBacks (?)
LinkBack to this Thread: http://www.routerforums.com/table-mounted-routing/4063-model-320-17542-table-routing.html
Posted By For Type Date
Sears router - BT3Central Forums This thread Refback 03-20-2009 11:40 PM
Router for routing table fredtrumble Table-mounted Routing 1 12-09-2007 07:53 PM
From Table Routing To A Shaper cabinetman Table-mounted Routing 6 06-13-2007 07:21 PM
Table Routing Direction berry Table-mounted Routing 4 01-03-2006 06:48 PM
Table routing template tom Table-mounted Routing 1 11-10-2005 01:57 PM
routing curved edges on a router table John B General Routing 3 01-14-2005 10:50 AM
