| Table-mounted Routing Discussions solely based on operations that are using the table-mounted router. Bob and Rick say "More than 90% of all operations using the router can be done with the table-mounted router. |
| | #1 |
| Registered User New Member | What is the best way to mount a table top to the base. Is wood movement a concern with a top that has melamine on both surfaces and the edges finished too? Are figure 8 fastners OK? The base is still in design stage so open to all options. Thanks |
| | #2 |
| Senior Moderator Supreme Forum King | If your table top has melamine or other plastic laminate on both the top and bottom surfaces it will not move. Figure 8 fasteners are a good choice. There are other products and methods such as "Z" clips, using woodenblocks trimmed into an "L" shape or using the new top attaching bits to rout slots in corner braces so screws can move if need be. Perhaps understanding how the wood moves will help even more. Think of your wood as being a bundle of straws. Moisture can easily pass in and out of the ends with no effect on the length. But the moisture takes up space and can cause the "straws" to move apart or side to side. This cross grain movement is what we try to compensate for when attaching a top or building panels.
| | #3 |
| Forum Moderator Supreme Forum King | Good info provided by Mike as always. Another thought would be to use dowels if quick knock down is desired for storage.
__________________ Cheers, Bob |
| | #4 |
| Registered User Forum King | Another possibility is to use threaded inserts in your top to take the fixings. That way you can insert/remove the screws as many times as you like without eventually wearing out the holes.
__________________ Pete I've cut it twice and it's still too short! But only at one end. |
| | #5 | |
| Forum Contributer Supreme Forum King | Hi saddlesore I know this may not be what you want BUT the simpler it is ,always works the best . Drill one hole in each corner of the top and into a corner block in the base cabinet,then put in some Allen Flat Hd. Cap Screws in that turn into some T-Nuts in the corner blocks.. You can remove the top if you need to replace it with one Allen Wench quick and easy or to store it away ![]() Bj ![]() Quote:
| Table Base | delirous26 | Table-mounted Routing | 11 | 09-25-2007 05:53 PM |
| Which base do I use on my home made table? | popeyebedford | Table-mounted Routing | 1 | 07-08-2007 02:56 PM |
| Hitachi M12V table mount questions | vwmowery | Table-mounted Routing | 7 | 10-04-2006 07:53 PM |
| Modifying Table Router base | desertfox87109 | Table-mounted Routing | 7 | 10-14-2005 03:54 PM |
| Table mount routers... | Bluegillman | General Routing | 1 | 12-02-2004 10:37 AM |
