Table-mounted Routing Discussions solely based on operations that are using the table-mounted router. Bob and Rick say "More than 90% of all operations using the router can be done with the table-mounted router.
Thread Tools Display Modes
Old 05-23-2007, 12:19 AM   #11
curiousgeorge
Supreme Forum King
curiousgeorge's Avatar
First Name: George
curiousgeorge is on a distinguished road
Hey Joe. Check out this sight. It's a 20 megabit download of a shareware Raised Panel Calculator. I haven't tried it but it might be just what you need.
http://www.canadiancontent.net/tech/...nel_Doors.html
It won't cost anything to try it out.
Here is another free one but it needs Excel to work...
http://www.cheyennesales.com/download/rpdcalc.htm
and here is a free trial download for another one...
http://www.softwareforwoodworkers.com/html/doors.html
George
For those who haven't already done so...
PLEASE! PLEASE! Fill in your first name and location in your profile. I like to know who you are and where you are from. If you don't want me to know who you are, then I don't want to talk to you.
curiousgeorge is offline   Top - Reply with Quote
Old 05-23-2007, 08:01 AM   #12
lablover
Forum Fanatic
lablover is on a distinguished road
Thanks George.
So this post has been very helpfull to say the least. I didn't realize that the rails and styles are 2 7/16. I was going to go with 1 1/2 but guess not. I'll take a look at some of the shaker style cabs at the local home depot and see how they are done. Plan on making some MDF doors today as practice. Actually, Re-modeling the basement has spured all this and I realized I have to make some type of door to put over the breaker box Sounds like a good project for MDF doors to paint!
Looking forward to posting a few pics of the router table as well. Looking pretty good. All I need now is drawer faces and a door and I'm set.
BTW What is a standard overlay for face frame cabs? the face frames are 1 1/2"
Thanks a ton everyone. God I love this board.....................and all my new tools
Joe
lablover is offline   Top - Reply with Quote
Old 05-23-2007, 08:42 AM   #13
Woodnut65
Forum Geek
Woodnut65 is on a distinguished road
Hi Joe: you can practice on any material if it is the same thickness as the maple you will use. I would suggest pine or poplar. Oak-Park has a program to do exactly what you want. it is SPO140, and costs around 35. USD. In the meantime I'll try to give you some info.
1. determine the overall size the finished door must be counting any over laps on to the face frame if you use one.
2. determine the size of the stiles and rails, in your case you say you want them to be
1 1/2" wide. when you cope the rail ends most router bits and sets will use 3/8ths"
in depth of cut. Both ends are coped so that means you must add 3/4" to the rail dimensions. The copes in the rails are made first, using a sled and back up board for reduce chip out. The stile bits are then installed into the router and both rails and stiles get machined. As an example if you wanted a door 12" wide and 18", and the width of the stiles and rails are to be 2" you would cut the following parts.
2 stiles 2" by 18 " long. 2 rails 2" wide. The length of the rails would be
the width of the finished door ie 12" minus 4" for the with of the stiles plus 3/4"
for the part of the cope one each end (3/8") The panels, raised or flat would be the same width as the rails ie 8 3/4" the length would be 18" minus 4 " for the width of the
stiles, plus 3/4" for the bottom and top of the panel to fit into the slots of the top and bottom rails. The panel would be 8 3/4" wide X 14 3/4" long. Hope this helps.
Woodnut65
Woodnut65 is offline   Top - Reply with Quote
Old 05-23-2007, 10:49 AM   #14
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi lablover
Here's some snapshots, they will help, from the old cat. from sommerfeld tools.
click on the snapshots to blow them up (hit the F11 key 1st) so you can read the details.
You can also put them on your PC ,just view them and then right click on them and select copy image or save as then make a new folder on your desktop and paste them in, then you can print them out or just save them when you need to go back and check on a item or two.
NOTE**** You don't need to buy the templates you can make your own quick and easy,,,, use some 1/4" to 1/2" thick MDF or hardboard take your compass and draw a BIG cir. on the 14" wide stock that's about 8" to 10" long, then take it to the band saw and cut it on the line, then light sand the edges, then take a magic marker and mark them for 10" to 12" panel doors. mark them part A and part B , you will need both parts to make the panels and the frame parts.
Start your cir. about 4 1/2" down from the left and the right side of the top of the 14" wide board.
Put in a band saw slot for the center mark,,,see snapshot below
Bj
calculating-door-sizes-6683.jpg  calculating-door-sizes-6684.jpg  calculating-door-sizes-6685.jpg  calculating-door-sizes-nail-pins.gif
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 05-23-2007, 01:47 PM   #15
lablover
Forum Fanatic
Woodnut, Bob
OUTSTANDING..Clear as a bell now. Got sidetracked today on the router table so no chance to do practice cuts. I will say however the router table is a wonder to look at. She sure did turn out purrrdddyyyy..Sans drawer fronts and doors..hehehhehe
Those are next!! BTW..Incra says my order wont ship till Friday or tues of next week...Waaaaaaaaaaaaaaaaaaaaaaaaaaaahhhhhhhh
I want my LS Super system Now!!
Again, thanks to everyone for all the help. Will post pics of the RT tonight hopefully...Almost completed anyway
Joe
Calculating template sizes ceetee Guide Bushings and Templates 4 05-10-2008 10:19 PM
Calculating Start/Finish Cut Location YellowLabProject Starting Off 10 10-31-2006 10:57 AM
