Rate This Thread - Aluminium.
Thread Tools Display Modes
Old 11-27-2004, 02:31 PM   #1
PaulM
PaulM is on a distinguished road
Default Aluminium
I need to open a 1/4" slot down the 60 inch length of a light wall aluminium square tube. I was going to use a solide carbide spiral bit with the router mounted in the table. Does anyone have suggestions or experience with such abuse of a router?
PaulM is offline   Top - Reply with Quote
Old 11-27-2004, 02:56 PM   #2
ejant
Router King
Supreme Forum King
ejant's Avatar
ejant will become famous soon enough
You will not be abusing the router or bit.
Keep the speed well below 10,000 rpm and a very slow rate of feed. You'll be very happy with the results.
ejant is offline   Top - Reply with Quote
Old 11-27-2004, 09:56 PM   #3
scooter
New Member
scooter is on a distinguished road
Put duct tape along the al. prior to routing. Saw this idea on the net somewhere for use when using a cutoff saw on aluminium and it made a huge difference to the amount of swarf left on the edges after the cut.
Cheers.........Sean
The beatings will continue until morale improves...
scooter is offline   Top - Reply with Quote
Cutting aluminium with a bandsaw? Check twice! Tools and Woodworking 8 05-15-2008 04:17 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108
