| Table-mounted Routing Discussions solely based on operations that are using the table-mounted router. Bob and Rick say "More than 90% of all operations using the router can be done with the table-mounted router. |
| | #11 |
| Marine Engineer Forum King | Niki, I think taking only one spring out might make it more difficult, causing it to kick over to one side. The best way would be to find some 'softer' springs. The hard part is finding them. For work purposes I've had custom springs manufactured, and it was not that expensive for the large batches (100 springs -- $200), but I don't know how cost effective that would be on a real small run. You may be able to find an industrial supply company/catalog that has something you could use. I would NOT cut your springs, since that will only reduce their tension over part of their range, and you can't go back should you cut too short..... The only other thing I could think of is for you to use your ingenuity to engineer your own version of the WoodRat plunge bar. http://woodrat.com/plungebars.html Hope this helps,
| | #12 | |
| Forum Contributer Supreme Forum King | Hi niki I would not cut them , once cut that's it you can't fix it or change it,,this is what I would try take some fine wire and tie up 2 or 4 coils in the center of the spring and then give it a try...this may do it...if you have some of the picture hanging wire and take one wire out of the rap and use it..also some of the small cable (1/8" type that has 8 or more in the rap...the center one is the best)I do like jigs , anyone can do it one time but to do it over and over the same way it takes a jig/fixture.. ![]() Bj ![]() Quote:
| | #13 |
| Registered User Forum Geek | Thank you BJ I'll give it a try. I still have some thin stainless steel "Safety wire" from the times that I was aircraft mechanic...35 years and it still looks like new...yes, it's Made in USA...at the times of the good old Boeing 707... Thanks niki |
| | #14 |
| Forum Contributer Supreme Forum King | Hi niki You'er Welcome pull your Safety wire tool out of the tool box and give it a try can't hurt ![]()
| | #15 |
| Registered User Forum Geek | Hey BJ That's exactly the one that I was using...sadly, I don't have it anymore... Regards niki |
| | #16 |
| Forum Contributer Supreme Forum King | Hi niki They are great tools, at one time I sold many of them to aircraft mechanics ![]() It's the base tool they all use ...
__________________ PodCast videos RWS on YouTube http://www.routerforums.com/86898-post1.html Besure and click on the Up Arrow key ▲ on the Youtube video, you can select other youtube videos on router tables ![]() http://www.woodworkingonline.com/?s=dovetail Machine Cut ▼ http://www.woodworkingonline.com/200...cut-dovetails/ http://www.woodworkingonline.com/woo...podcast-store/ http://www.woodshopdemos.com/menu2.htm Bob J. Last edited by bobj3; 06-22-2007 at 09:42 PM. |
| | #17 | |
| Retired Moderator Supreme Forum King | Quote:
I have gotten pretty good at it as well.Corey
__________________ My Carving Website: The Iowa Woodcarver http://iowacarver.tripod.com/ My Shop Website - Woodshop 51503 http://woodshop51503.tripod.com/ | |
| | #18 |
| Registered User Forum Geek | This is exactly what I love about this forum. A true hobbyist like Niki takes the time and effort to show his creations, Bobj3 and his constant searching for right tool for the job- and the bargains that can be found. Mike for having a better than good knowledge of finishing and the list goes on. I am right in the middle of remodeling my shop and can't wait to get on with the long list of projects. The inspiration here is priceless. -Derek |
| | #19 |
| Forum Contributer Supreme Forum King | Hi Niki, you're idea of fitting 4 boards together then passing through the saw is definitely the way to go, as for making all 4 at the same time, I don't know, if there is a stuff-up, we lose the lot or make the box smaller!
__________________ Harry |
| | #20 |
| Registered User Forum Geek | Hi Harry I just came from the garage after making the finger joints on all 4 boards together and I see your comment about making them all at the same time... Please have a look in the new post "My first finger joint box" Cheers niki |
| Finger joint size. | DavePowers | Jigs and Fixtures | 5 | 09-26-2007 06:28 PM |
| Leight finger joint template | S Bolton | Jigs and Fixtures | 0 | 07-29-2007 12:58 PM |
| My first finger joint box | simplenik | Table-mounted Routing | 6 | 06-24-2007 09:52 AM |
| Chipout when using finger joint jig | jihhwood | Jigs and Fixtures | 3 | 01-03-2007 08:33 AM |
| Finger joint jig | Spacemanspiff | Jigs and Fixtures | 4 | 10-06-2004 04:46 AM |
