| | #1 |
| Registered User Forum Geek | Good day Today, I made it... Still, a lot is missing...the fence clamping, sliding stops, clamps to clamp the boards and others but... It's working very good and rolling very smooth. I lifted the bit 1/8"~5/32" at every pass but I feel that I can take more depth in each pass (probably because I'm used to the old router). The setting is very easy and I can set it precisely to the length of the required mortise. The stops are located on the fence so there is no problem of long boards. After setting and clamping the board, I just "roll" the jig from one stop to the other, lift the bit and roll again till the depth stop. I used 10 mm (3/8") bit and on one of the pics you can see a 10 mm dowels inserted, very precise. Sorry, I did not "Text" the pics, it was only a test... Regards niki ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
| | #2 |
| Forum Administrator Supreme Forum King | Thanks for sharing! ![]()
__________________ Mark, Administrator and Technician of RouterForums.com Contact RouterForums.com Refer a friend to RouterForums.com! |
| Need help mortising hinges | johnt | Guide Bushings and Templates | 11 | 04-27-2008 10:42 AM |
| Mortising Jig | bobj3 | Jigs and Fixtures | 5 | 12-25-2007 12:42 PM |
| Mortising bit | Woodworker 52 | Router Bits - Types and Usage | 3 | 07-14-2007 02:50 PM |
| Hinge mortising bit and straight bit. | -Sam- | General Routing | 1 | 03-29-2006 11:58 AM |
