Thread Tools Display Modes
Old 07-05-2007, 12:21 AM   #1
skinner
New Member
skinner is on a distinguished road
Default router table problems
i am attempting to joint a few cedar boards prior to laminating them together to make a larger piece of furniture.
the cedar is one inch actual and I am using a half inch straight bit, however, when i get to the end of the board, the board gets too close to the bit which then cuts too deep, spoiling the whole effort.
I have closed up the opening to the bit but that still does not seem to help...any assistance to help me overcome this vexing problem will be greatly appreciated.
skinner is offline   Top - Reply with Quote
Old 07-05-2007, 01:07 AM   #2
Dr.Zook
Supreme Forum King
Dr.Zook's Avatar
Dr.Zook is on a distinguished road
Send a message via Skype™ to Dr.Zook
Thanks for joining our forums skinner. Glad to have you as a member. Hope you get your problem worked out and continue to participate.
Dave
the "Doctor"
Dr.Zook is offline   Top - Reply with Quote
Old 07-05-2007, 02:05 AM   #3
Senior Moderator
Supreme Forum King
Mike has disabled reputation
The most likely cause is your infeed fence is not parallel to your outfeed fence. Unplug your router and hold a good straight edge on the outfeed fence so it extends along the infeed fence. The gap must be even along the infeed fence, if not, place shims behind it until it is. That should solve your problem.
Old 07-05-2007, 08:42 AM   #4
kp91
Forum King
kp91's Avatar
Skinner,
Snipe can be a pain. One solution is to cut the boards 'longer' and then trim off the damaged ends. Another solution, is to carefully re position your hands as you are feeding the stock, so that towards the end of the cut you are maintaining pressure on the outfeed side. Just be mindful of where the bit is (a guard is a good idea) when you put your hand fwd of the bit.
1 John 1:9
Old 07-05-2007, 10:23 AM   #5
Joe Lyddon
Banned
Supreme Forum King
Joe Lyddon's Avatar
Joe Lyddon is on a distinguished road
skinner,
W e l c o m e . . A b o a r d !!
Do you have relatives in Chico, CA by any chance? Do you know a David Skinner?
Yes, they key to joining is to put control onto the OUTPUT section ASAP after starting... and away from the INPUT side.
Besides both sides of the fence must be parallel, the OUTPUT fence wants to be slightly (1/32" or so) closer to you than the INPUT side... in that it gets cut first against the input fence and the output merely wants to accurately support the wood as it comes out of the cutting stage... So, it's important to keep more pressure against the output fence as possible during the cut...
If you put any pressure on the input side especially toward the end of the cut, it will cut deeper than you want.
I would rather make two cuts at 1/32" than one cut at 1/16"... but that's just me...
Good luck.
Joe Lyddon is offline   Top - Reply with Quote
Old 07-05-2007, 10:10 PM   #6
oldnewbie
Forum Fanatic
oldnewbie's Avatar
oldnewbie is on a distinguished road
Hey Joe, thanks for the tip. I've been having the same problem, but you've made it clear what I was doing wrong. Gotta try that in the am.
Neal
oldnewbie is offline   Top - Reply with Quote
Old 07-05-2007, 10:22 PM   #7
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Joe
Can you take a picture/snapshot of how you set that up on your router table.
I know how I do it but I would sure like to see how you have it setup on your table, do you use a offset fence or what ,with a split type fence ?????????
Plus how and what to you use for the 32nd. offset (setting it up)
THANKS
Bj )
Originally Posted by Joe Lyddon
skinner,
Good luck.
Bj
Old 07-05-2007, 11:46 PM   #8
Router is still my name
Forum King
Router is still my name's Avatar
Router is still my name is on a distinguished road
http://www.woodshopdemos.com/rtrplnr.htm
router è ancora il mio nome
Router is still my name is offline   Top - Reply with Quote
Old 07-06-2007, 12:45 AM   #9
skinner
New Member
Default router problems
thanks for the replies, will try what you suggest.
Old 07-06-2007, 06:14 AM   #10
harrysin
Forum Contributer
Supreme Forum King
harrysin's Avatar
harrysin is on a distinguished road
"I would rather make two cuts at 1/32" than one cut at 1/16"... but that's just me..."
I can assure you that it isn't just you Joe!
Harry
harrysin is offline   Top - Reply with Quote
Router Table Flush Trimming Problems jimcrockett Table-mounted Routing 12 03-23-2008 08:06 PM
Master craft 10A plunge router with table problems davistan Table-mounted Routing 2 01-01-2008 04:39 PM
Insert Plate size and 11.5" handle spread; how to prevent problems Ladd Table-mounted Routing 34 12-14-2007 01:08 PM
Motorized Router Lift - Eagle Lake Style johnwnixon Table-mounted Routing 10 09-13-2007 06:59 AM
Problem mounting Dewalt Router to Caftsman Table Saw apollo2000 General Routing 8 05-22-2007 06:42 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109
