| Table-mounted Routing Discussions solely based on operations that are using the table-mounted router. Bob and Rick say "More than 90% of all operations using the router can be done with the table-mounted router. |
| | #1 |
| Registered User New Member | I built a router table, and managed to sink a 3/16" piece of clear acrylic flush to the 3/4" good grade plywood. It's a 2x4' piece and I screwed it to an old bench that was in this fixer upper when I bought it. I saw an educational TV program on router usage and noted that the instructor was using his plunge base mounted on an phenolic plate to do his table routes. I wondered why was he using the plunge base and not the fixed base. I am still wondering because I mounted my Skil 1825 on the plunge base and tried to cut a dado (slot) 1/4" deep in a piece of soft 3/4" pine about 2 feet long, and the depts was half of that when I got through. Even though I measured it over and over I still got a difference in the cut. Something changes between the time I have the router on the table top adjusting (which is truly awkward and imprecise to me) and the time I put it back in the table and setup my home made fence and take a cut. There seems to be no way to fine tune the depth of cut, as the adjustment knob only goes a short distance before binding up...I don't get it at all...I am totally lost as to how to work with this Skil router... Any ideas on where I can get some instructions? The skil people don't offer much in the way of user information...thanks |
| | #2 |
| Forum Contributer Supreme Forum King | Hi Popeye They will both work but it's best to use the standard base for the router table in that way you can just pop in the motor in the plunge base, plus you don't need to remove the springs....but the deepth of cut should not change once you set it.. http://www.amazon.com/Skil-1825-2-In.../dp/B0000C6DY0 User Manual below http://www.amazon.com/Skil-1825-2-In.../dp/B0000C6DY0
| Looking for input on home built router table | italian biker | Table-mounted Routing | 1 | 05-29-2008 08:07 AM |
| home made router table | vegeta88 | Table-mounted Routing | 16 | 02-08-2008 09:52 AM |
| Home made table | vapochilled | Table-mounted Routing | 9 | 09-09-2007 02:21 PM |
| Mounting Porter Cable 892 Fixed Base to Router Table | Pack52 | Table-mounted Routing | 4 | 02-14-2006 05:50 PM |
| overcomming home made router table snags | matey | Table-mounted Routing | 1 | 10-16-2005 12:46 PM |
