| Table-mounted Routing Discussions solely based on operations that are using the table-mounted router. Bob and Rick say "More than 90% of all operations using the router can be done with the table-mounted router. |
| | #11 |
| Registered User Supreme Forum King Join Date: Nov 2006 Location: Fort Worth,Texas USA First Name: George Posts: 1,580 ![]() | Here's some pics of the fence I made out of 3/4 MDF.
__________________ George For those who haven't already done so... PLEASE! PLEASE! Fill in your first name and location in your profile. I like to know who you are and where you are from. If you don't want me to know who you are, then I don't want to talk to you. |
| | #12 |
| Registered User Forum Geek | George, it's difficult to tell for sure from the pics, but that looks like one BIG table. Is that one you made? Any drawbacks to haviing that large a table? I can see what the advantages will be, but just looking for some negatives. Brian
__________________ A married man should forget his mistakes. There's no use in two people remembering the same thing! |
| | #13 |
| Registered User Supreme Forum King Join Date: Nov 2006 Location: Fort Worth,Texas USA First Name: George Posts: 1,580 ![]() | Hi Brian, I did make the table. It's 24 x 48 and so far I have found no disadvantages. If you want to see more of the table go to: http://www.routerforums.com/table-mo...le-fences.html
| | #14 |
| Registered User Forum Geek | Thanks George. Going to have to keep that in mind when I finally get around to making my table. My Craftsman is serving me well for the moment, but already proving to be a bit small. Just have to decide which fence design is better, yours with the sliding wings or extensions, or Bj's with the replaceable inserts in the center. That's the biggest problem with my fence, I have this HUGE cavity around the bit... gets interesting routing small pieces. Might make that an upgrade for my current table, until I can build a better one. Time will tell. Brian
| | #15 | |
| Retired Moderator Supreme Forum King | Quote:
__________________ My Carving Website: The Iowa Woodcarver http://iowacarver.tripod.com/ My Shop Website - Woodshop 51503 http://woodshop51503.tripod.com/ | |
| | #16 | |
| Registered User Forum Geek | Quote:
This was a 2nd hand purchase from a friend of mine. I've got some MDF left over, might just try and fab a fence in the next week or so.Brian
__________________ A married man should forget his mistakes. There's no use in two people remembering the same thing! | |
| | #17 |
| Registered User Forum Geek | That was one of the things I liked least about my last table - one of those cheap metal ones with the two plastic pieces serving as a fence. Probably much like the one you described. WAYY too much space between them. After looking at both the sliding wings and the t/g system - I'm mulling around a combination of the two. My big quandry now is the mounting - Whether to use a straight t-track system - or the pivot - or clamping down to the table (with built-in clamps). |
| | #18 | |
| Forum Contributer Supreme Forum King | Hi Brian Making the hole smaller is no big deal, just some plastic or some 1/4" thick MDF and bit of time and you have it done with... the one below is the Oak-Park base plate with the BIG 3 1/8 " hole in.. But now it's 3 3/8" hole with a lip to hold the insert rings.. the rings are easy to make if you need any help just ask Bj ![]() =========== Quote:
__________________ PodCast videos RWS on YouTube http://www.routerforums.com/86898-post1.html Besure and click on the Up Arrow key ▲ on the Youtube video, you can select other youtube videos on router tables ![]() http://www.woodworkingonline.com/?s=dovetail Machine Cut ▼ http://www.woodworkingonline.com/200...cut-dovetails/ http://www.woodworkingonline.com/woo...podcast-store/ http://www.woodshopdemos.com/menu2.htm Bob J. Last edited by bobj3; 07-27-2007 at 11:34 PM. | |
| | #19 | |
Never thought about putting a front on my existing fence.. a LOT easier then making a new one right now. I will, in time, just not now... I've got an insert plate already, just a matter of getting started on the table. As for the inserts, fostner bit of the desired size followed by a hold saw? Just a quick guess. Any help is greatly appreciated. Brian
| | #20 | |
| Forum Contributer Supreme Forum King | Hi Brian Well the hole saw 1st, then the fostner bit,,, Almost all hole saws use a 1/4" drill bit to keep them true,,,,and they must be dead on the O.D. because you must press them in place becasue you don't want them to pop out when you have the router running... The 1/4" hole is the key ,,,,I don't know if you have a big hole saw most don't but you can used a jig saw or a band saw to make them with and a small jig to sand them down to the right size... the easy jig is below,,,, Once you have the outside right on, then drill the center out with the fostner bit But do make many sizes from 5/16" ID to 2 1/2" ID .. The 1st one you will want to make is the lip ring that can be screw in place or glued in place, it will support the other press in insert rings... Bj ![]() Quote:
__________________ PodCast videos RWS on YouTube http://www.routerforums.com/86898-post1.html Besure and click on the Up Arrow key ▲ on the Youtube video, you can select other youtube videos on router tables ![]() http://www.woodworkingonline.com/?s=dovetail Machine Cut ▼ http://www.woodworkingonline.com/200...cut-dovetails/ http://www.woodworkingonline.com/woo...podcast-store/ http://www.woodshopdemos.com/menu2.htm Bob J. Last edited by bobj3; 07-28-2007 at 01:34 AM. | |
| fences | Jerryw | Introductions | 5 | 07-23-2007 01:14 PM |
| Router Table Fences | curiousgeorge | Table-mounted Routing | 12 | 01-28-2007 12:56 AM |
| router fences | Bob James | Introductions | 4 | 10-08-2006 07:16 PM |
| fences | sameads | Introductions | 2 | 08-04-2006 01:50 PM |
| fences | donniea | General Routing | 1 | 06-12-2006 02:53 PM |
