Table-mounted Routing Discussions solely based on operations that are using the table-mounted router. Bob and Rick say "More than 90% of all operations using the router can be done with the table-mounted router.
Thread Tools Display Modes
Old 07-28-2007, 08:10 AM   #21
BrianS
Forum Geek
BrianS's Avatar
BrianS is on a distinguished road
Thanks Bj. I do have a hole saw, an old one, but it's hardly ever been used so still sharp. Now just have to check and see if I have the correct size. Could a circle cutter be used on this? I don't have one, but I've been thinking of buying one.. can't have too many tools..
Brian
A married man should forget his mistakes. There's no use in two people remembering the same thing!
BrianS is offline   Top - Reply with Quote
Old 07-28-2007, 10:01 AM   #22
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Brian
"Could a circle cutter be used on this?" = you bet, they are great but it must be used in a drill press.....and the stock must be clamped down....
they do have a small downfall ,they can only go down to 1 3/8" the norm.
The one I have and use is the one below ▼
H7538 Circle Cutter w/ Fine Adjustment
http://www.grizzly.com/products/h7538
I also have the two blade cutter type and they just don't work well
very hard to get them set up true, it's a big deal when it comes to cutters if one is off by .005, double cut thing...one cutter once to pull if off center.
Bj
Brian
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 07-28-2007, 10:52 AM   #23
harrysin
Forum Contributer
Supreme Forum King
harrysin's Avatar
harrysin is on a distinguished road
Hi Brian, regarding method of fitting fence to table, is there any reason why you can't fit tee nuts beneath the table, two, or even three rows, depending on the amount of front to back movement you require, then it's a very quick job to adjust. As for the hole around the cutter, as you can see, my fence has a large one but it's just a matter of clamping a piece of 1/8" MDF and drawing the fence over the cutter to give a zero clearance. Just a thought, bearing in mind the forums motto: KISS!
Harry
harrysin is offline   Top - Reply with Quote
Old 07-28-2007, 10:56 AM   #24
harrysin
Forum Contributer
Supreme Forum King
harrysin's Avatar
Bj, I just love the slotting saw idea for decapitating boxes, do you slip shims in the sides as you go, to keep the box vertical?
Harry
Old 07-28-2007, 10:59 AM   #25
Drugstore Cowboy
Forum Geek
Drugstore Cowboy's Avatar
Drugstore Cowboy is on a distinguished road
Since the topic has turned to inserts -
Let me throw out another alternative for those who might have a router but not a drill press -- or - who might just prefer the router.
I learned this system doing research for my new table.
I used a Jasper circle jig from Woodcraft -- but you can make your own
Drugstore Cowboy is offline   Top - Reply with Quote
Old 07-28-2007, 11:07 AM   #26
Drugstore Cowboy
Forum Geek
BTW --
Still looking for input on my original question -
Particularly now down to 2 things ---
- specifics on how best to set up the 'pivoting' fence
Particularly if I might want to move back and fort between that and straight T-Track
- Pros and cons of using designed in clamps to clamp to the table itself -
THANKS
Old 07-28-2007, 11:17 AM   #27
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Harry
I rip two sides then put in shims into the two sides with just a bit of masking tape to hold them in place and then rip the other two ends,,, the shims are just a bit over size to press the parts apart but just a bit, on the last cut the lid will just be free and the masking tape is still holding the box as one part...
The blade I use is battery type saw that is 3 3/8" in dia. and will cut up to
1 1/8" thick stock clean.
I made my own arbor but one can buy one from Grizzy at the right price..
The blades needs to be reamed out (.010) just a bit, because it has a METIC hole in it.
G1438 Slitting Saw Arbor
http://www.grizzly.com/products/g1438
Bj
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 07-28-2007, 11:22 AM   #28
BrianS
Forum Geek
BrianS's Avatar
Originally Posted by bobj3
Hi Brian
Bj
No problem, I do have a drill press. A small benchtop model, but it should be up to the task. The reason I was leaning towards the circle cutter, besides being cheap and wanting to purchase a tool that will have many uses, is that I felt the circle cutter could also cut the lip on the insert, as well as cut the insert out. Adjusted to the correct size, and then only cut thru partially, adjust again and then cut completly thru. Sounds good on paper anyway.
Something else to put on the list of shop improvements.
Brian
Old 07-28-2007, 11:33 AM   #29
challagan
Supreme Forum King
challagan's Avatar
challagan is on a distinguished road
Thanks Cowboy, that's a neat jig. I think Bobj uses one of those as well. worth the investment. It's on the list
http://iowacarver.tripod.com/
My Shop Website - Woodshop 51503
http://woodshop51503.tripod.com/
challagan is offline   Top - Reply with Quote
Old 07-28-2007, 11:34 AM   #30
BrianS
Forum Geek
BrianS's Avatar
Harry, the current fence has a slot in one end, and the other has a slot in the table, so adjustment is pretty easy, from either end. And yes, clamping a piece of mdf to the face of the fence would solve the problem caused by the huge cavity in the fence. Think Bj suggested it ahead of you.
I'm still cleaning out my garage/shop so that, and the inserts, will have to wait for a bit but I will get to it sooner or later. BTW, Mike says I can't send you any pics of my garage else I'll be put in detention by you.
Brian
fences Jerryw Introductions 5 07-23-2007 01:14 PM
Router Table Fences curiousgeorge Table-mounted Routing 12 01-28-2007 12:56 AM
router fences Bob James Introductions 4 10-08-2006 07:16 PM
fences sameads Introductions 2 08-04-2006 01:50 PM
fences donniea General Routing 1 06-12-2006 02:53 PM
