Table-mounted Routing Discussions solely based on operations that are using the table-mounted router. Bob and Rick say "More than 90% of all operations using the router can be done with the table-mounted router.
Thread Tools Display Modes
Old 08-28-2007, 09:51 AM   #11
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Thanks Trap for the link,,,it took a bit to get to it but it's a good one on the Horz.table
http://lumberjocks.com/jocks/eaglela...king/blog/1292
http://www.eaglelakewoodworking.com/index.htm?mlcs.htm
Video Below ▼
http://www.eaglelakewoodworking.com/...google_med.htm
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 08-28-2007, 10:33 AM   #12
trap
Forum Fanatic
trap's Avatar
trap has a spectacular aura abouttrap has a spectacular aura about
bobj3.
I worked on that link for some time and could not get. Thanks for the direct link.
Bud
The Geezer
trap is offline   Top - Reply with Quote
Old 08-28-2007, 10:56 AM   #13
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Trap
You'er Welcome ,,,they can be tricky sometimes
Here's a trick I use from time to time..
Right Click on the item you want the URL for and Select, Copy Link,you should see 2 or 3 types...then just paste that into NotePad and use it in your post.
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 10-10-2007, 07:20 PM   #14
Lee Brubaker
Forum Fanatic
Lee Brubaker is on a distinguished road
From the responses it would seem to me that some are confusing a horizontal router table by calling it a vertical table.The prevailing terminalogy that Iam familiar with is as BobJ used ie: standard table versus horizontal table. One of the advantages re a horizontal table is that it enables the use of a smaller handheld router for panel raising because a vertical panel raising bit's dia. of 1". For us nervous nellies those big panel raising bits used in a standard table kinda takes the fun outta routing. I have both types of tables & I find the horizontal table handier to use for some operations than the standard table. For example, edge jointing, mortising, tenons, & if you really want to get carried away you can make raised panels utilizing plywood if you are careful matching grain when gluing solid wood to the panel where the machining is going to take place. Good for sliding & blind dovetails as well.
Lee
Lee Brubaker is offline   Top - Reply with Quote
Motorized Router Lift - Eagle Lake Style johnwnixon Table-mounted Routing 10 09-13-2007 07:59 AM
