| | #1 |
| Registered User Forum Fanatic | Just wondered if any of you who use an Hitachi in a table have had this problem? I was using it today when it slowed down and then stopped comletely! No matter what I did it would not re start. After a while it worked again and I assumed that a thermal cutout had activated. I decided to strip it down and blow out any accumulated dust and it was full of it needless to say. I normally use the vacuum on it after using it but it looks like this just wasn't enough. It is now running fine again with no problems. Just wondered if anyone had come across this problem notably 'Bob and Rick as they use these machines in tables all the time? Thanks. |
| | #2 |
| Senior Moderator Supreme Forum King | Bob and Rick used the Hitachi's in the early years of the show, Porter Cable in the more recent episodes. Template Tom has posted on the need to regularly blow out your router with compressed air. Thermal overload was what you had for sure with all the dross inside the case blocking air flow. You did exactly the right thing, good job!
__________________ Mike |
| | #3 |
| Registered User Forum Fanatic | Thanks Mike. I am afraid we don't get the show over here so I have only seen the early ones. I will remember that in future and blow out the router on a regular basis. I have good extraction on the fence so was surprised to find so much dust inside! Thanks again. |
| | #4 |
| Registered User New Member | I Use The M12v In My Router Table Also, My Router Did Not Stop But It Got Hard To Adjust. I Also Took It Apart And Cleaned It Out Each Time This Happened. As I Thought About The Problem I Realized That I Dont Have Enough Space Between The Bottom Of The Table And The Air Intake Of The Router, Only About 2-3 In. So I Got A Nylon Stocking And Covered The Intake Of My Router And It Works Quite Well. I Also Found That Even With My Vaccum Hooked Up I Was Still Etting Large Chips Falling Down The Exhaust Of The Router, So I Made A Plastic Tent To Make The Chips Fall To The Side Of The Router. It Is A Little Inconvient But Its Better Than Spending So Much Time Cleaning Out The Router. The Plastic I Use Is Actually To Use On Cutting Boards, My Wife Found It At Wal-mart. |
| | #5 |
| Registered User Forum Fanatic | Well it looks like it wasn't just dust in the workings of my Hitachi as it is still persisting in cutting out on me! I can only think that maybe there is a fault in the electronics as I have checked for loose wires but nothing found. I have had to change the Hitachi for my Freud for the time being but it looks like I may have to invest in a new Hitachi for the table. |
| | #6 |
| Registered User Jr. Member | Could it be the brushes are worn out? |
| | #7 |
| Senior Moderator Supreme Forum King | That sounds like a reasonable guess Alan. When troubleshooting we try to start with the most likely cause and go from there. Not owning an M12V I must defer to other members on the difficulty in checking the brushes.
| | #8 |
| Forum Contributer Supreme Forum King | Hi Alan I have a Hitachi mounted in one of my router tables I have, DUST can and will give the router fits,,It's not made to work upside down and all the saw dust/chips fall into all the open ports on the router,like the switch housing for just one of them, most routers have a strong fan to move/blow the heat out of the motor and the chips when it's use upright but the Hitachi has a small fan blade or to say no fan blade to move the air around the motor parts. But when it's up side down the saw dust will fall into the tail end of the router/brush's, it takes about 90 psi. to blow out the tail end of the router and must be done all the time, a quick way to keep it running is to pop the router out of the table after ever job and run it in the upright for just a bit ,this will let the chips and saw dust fall out and out of the router motor then with just a bit of can air blow it clean then drop it back in the table and your set for the next time you need to use it.. =================
__________________ Router Tables plans FREE, plus more http://www.absolutelyfreeplans.com/W...p_projects.htm Router Tip Archive http://www.routerworkshop.com/router_tip_glossary.html Calculators http://www.routerforums.com/dynamic-calculators/ Last edited by bobj3; 09-14-2007 at 10:29 AM. |
| | #9 |
| Registered User | The problem with the motor might be the variable speed control switch, which I have read is a weak point with this particular router. Unfortunately, the cost of a new switch is almost the cost of a new router. For RICKO, I had the same problem with my Hitachi so I went out and bought two plastic covers for the shafts that move to adjust the height. The ones for a Bosch router work good and cost about $10 or so. Cam |
| | #10 | |
| Forum Contributer Supreme Forum King | Hi newbiewoodworker Duck tape works great for the little job also ![]() ============== Quote:
__________________ Router Tables plans FREE, plus more http://www.absolutelyfreeplans.com/W...p_projects.htm Router Tip Archive http://www.routerworkshop.com/router_tip_glossary.html Calculators http://www.routerforums.com/dynamic-calculators/ | |
| 1/4" Collet for Hitachi M12V | RzzB | General Routing | 37 | 05-27-2008 08:11 AM |
| Setting the proper RPM on the Hitachi M12V | jrs4464 | General Routing | 5 | 01-10-2007 09:34 PM |
| Hitachi M12V | aztd | Table-mounted Routing | 2 | 07-26-2006 02:07 PM |
| Hitachi M12V and Bosch 1619EVS routers | LBrandt | Table-mounted Routing | 3 | 06-03-2006 10:42 AM |
| Hitachi M12V issue | Warren White | General Routing | 4 | 03-23-2005 10:03 PM |
