The Network:
 Recommended Stores:
RouterForums.com - Your Online Router and WoodWorking Community
Login
RouterForums.com Search:
    Advanced Search
FAQ
Reload this Page Making a Zero Clearance Fence for Drawer Lock Bit
Table-mounted Routing Discuss Making a Zero Clearance Fence for Drawer Lock Bit in the Routers forums; Just purchased a drawer lock bit that I'd like to experiment with, creating drawers from plywood for a router ...
New Reply | Quick Reply
Thread Tools Search this Thread Display Modes
Old 12-14-2004, 10:52 PM   #1
gerrym526
Jr. Member
User Info
Trader Rating: (0)
Gallery: View
gerrym526 is on a distinguished road
Question Making a Zero Clearance Fence for Drawer Lock Bit
Send Private Message | View Profile
Just purchased a drawer lock bit that I'd like to experiment with, creating drawers from plywood for a router cabinet. The recommendation is that a zero clearance fence insert, or in my case a zero clearance overlay fence is recommended to avoid tearout.
I've never made a zero clearance fence to fit a particular router bit, so I need to know the basics. Do you trace the pattern of the bit on the insert and then cut it out on a bandsaw, or do you install the router bit in the table mounted router, turn it on, and run the fence into the moving bit to cut the opening? (sort of like turning on your table saw and moving the spinning blade up into the table insert to create a zero clearance plate).
Thanks in advance for the help.
gerrym526 is offline   Top | Reply with Quote |
Sponsors
You currently aren't registered, click here to register.
Old 12-15-2004, 03:27 PM   #2
JohnnyTest
New Member
User Info
Trader Rating: (0)
Gallery: View
JohnnyTest is on a distinguished road
Actually the best answer is both of the above.
First you want to trace the bit and make a cutout using a bandsaw, but you only want to take out the middle, don't worry about the edges. When you have a small opening from the bandsaw you then put the fence back and move it through the bit.
By taking out some of the material with the bandsaw, you will not have to remove alot with the bit. Hope this makes sense.
JohnnyTest is offline   Top | Reply with Quote |
Old 12-16-2004, 01:03 AM   #3
reible
Supreme Forum King
reible's Avatar
User Info
Trader Rating: (0)
Gallery: View
You didn't mention the of material the fence. I'm guessing you know that you want to use a disposable piece and not to use the actual fence (unless you have a disposable fence). If it is Polyethelene then just cut into it, if using hardwood I might just do the same thing just slower. (see how it feels when you do it) I'm also sure you know to make sure you have no contact of bit to fence until the router is up to speed. You will want to go just deeper then the actual exposure you want and you will need to provide an exit for the chips on the backside.
Ed
reible is offline   Top | Reply with Quote |
Old 12-16-2004, 12:43 PM   #4
Woodnut65
Forum Geek
User Info
Trader Rating: (0)
Gallery: View
Woodnut65 is on a distinguished road
Hi: The easy wayto make a zero clearance fence is to take a board that is higher than
the bit and thick enough to accomodate the bit circumference. Fasten the out put side of the board to the router table with a clamp. Turn on the router while keeping
the board clear of the bit, then move the infeed side of the board into the bit. The bit
will have cut its own outline into the board. Then all you have to do is set the board
(fence) where it will cut as you require. Put a clamp on the infeed side, and re-tighten the out feed clamp. That's all thats needed.
Hope this helps, Woodnut65
Woodnut65 is offline   Top | Reply with Quote |
Search this Thread:
Advanced Search
Face Lift for the Router Fence bobj3 Jigs and Fixtures 7 06-05-2006 08:57 AM
Some Thoughts on Fence Control Gilbear Table-mounted Routing 5 12-20-2005 05:38 PM
Powered by: vBulletin Version 3.0.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd. - Copyright 2007 RouterForums.com - Search Engine Optimization by vBSEO 3.0.0
Professional Web Hosting provided by: RosenMill Technologies
