| | #1 |
| Registered User Sr. Member | I made a jointer fence for my router table and now that I have learned to use it properly I have a question. So far all I have done is 3/4" material with a 1" long straight bit. It works well. I was wondering if I could do the same on thicker material say the 2" side of a 2x4 with a longer straight bit like this one. ![]() Would this be too much material? |
| | #2 |
| Registered User Forum King | Sure you could, but if your router has a 1/2" collet you would be better off with a 1/2" shank.
__________________ Mike - Retired FoMoCo Tradesman My Gallery @ http://www.routerforums.com/axlmyks-stuff/ |
| | #3 |
| Forum Contributer Supreme Forum King | Hi Petersen I also have the same bit and they do work well when using a template and a brass guide in the router table base plate but the blank must be cut with in 1/8" of the right size...your asking the bit to do alot of work and it should be running at high speed...24,ooo rpm. to help take the load off the bit...go so and easy..they also work well to joint the face of the stock just a note use a top guard for this tall bit..if you are not using the fence... =========== Quote:
__________________ Router Tables plans FREE, plus more http://www.absolutelyfreeplans.com/W...p_projects.htm Router Tip Archive http://www.routerworkshop.com/router_tip_glossary.html Calculators http://www.routerforums.com/dynamic-calculators/ |
| | #4 |
| Forum Contributer Supreme Forum King | I think that you are expecting a lot from a 1/4" shank cutter flexing could be a real problem. Very light cuts would be the way to go.
__________________ Harry |
| | #5 |
| Banned Supreme Forum King | Yes, go with 1/2" shanks. |
| | #6 |
| Forum Contributer Supreme Forum King | Hi Peter I have never had one flex (1/4" shaft router bit) I have broke some ![]() They are made with high end steel the norm 125,000 to 170,000 psi. it takes tons of to bend one, and than they add the carb.blade to the side of the shaft and that puts it out of site...it will break b/4 it bends...but if you don't feel safe using one than by all-means use a 1/2" SHANK one.... ======
| | #7 |
| Registered User Sr. Member | I hadn't really thought about the 1/4" shank being a problem. I do have a router that can accept 1/4 or 1/2" so won't be a problem. That was the first example I found so I posted it. I was more worried about the thing flexing at high speed and making an uneven plane. |
| | #8 | |
| Banned Supreme Forum King | Quote:
The larger shaft increases smoothness; less vibration. There are other reasons... Bob, of Bob & Rick, has mentioned benefits of a 1/2" shaft a few times in their shows. IMHO, if you have a choice and can use a 1/2" shafted bit, USE IT... There are times where you may not be able to get a certain bit with a 1/2" shaft... then, by all means, use what you can get to do the job. I prefer 1/2" shafts and will use them over a 1/4" one whenever I can. Just my humble opinion... ... to each his own... | |
| | #9 |
| Registered User New Member | I bought a Shop Notes today (Tools and Jigs) that has plans for a router based jointer in the back of the magazine. There are some building notes that they have on there web site too. You can find it on shopnotes web site search for Router Jointer. I bought the hardware today to start mine. |
| | #10 |
| Registered User Sr. Member | I actually have a jointer fence I built that works well, but only for stock thinner than 3/4" as that is the longest cutter length bit I have. Which ShopNotes, the new one(96)? I haven't seen it yet, but the website says it has a tablesaw jointer. |
| Mixing Bosch 1617 Router fixed base with Craftsman professional router | sf_basilix | Starting Off | 5 | 01-21-2008 08:54 AM |
| Motorized Router Lift - Eagle Lake Style | johnwnixon | Table-mounted Routing | 10 | 09-13-2007 06:59 AM |
| RouterForums.com and Oak-Park.com - September 2006 Contest - VOTING STAGE!! | Mark | Contests Archive | 13 | 11-05-2006 02:23 AM |
| RouterForums.com and Oak-Park.com - September 2006 Contest!! | Mark | Contests Archive | 72 | 10-01-2006 12:02 PM |
| New Router my way | reible | General Routing | 14 | 06-10-2006 10:19 PM |
