Rate This Thread - glue for plastic laminate.
Thread Tools Display Modes
Old 09-24-2007, 08:29 PM   #1
S Bolton
Forum Geek
S Bolton is on a distinguished road
Default glue for plastic laminate
Router table has a small area of plastic laminate lifting up near the router plate insert. I need to get a good glue that can be injected in a small area to try to glue the laminate back down. Contact cement won't work due to the small area.
Any ideas?
Many thanks in advance.
sb
S Bolton is offline   Top - Reply with Quote
Old 09-24-2007, 09:27 PM   #2
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi SB
I use a two part Epoxy glue that can be injected in and under the laminate, you can get it from the auto parts store,, 30 sec.,1 min.5 min,etc.setup time..
I also use the super thick super glue with the spray that sets it in 10 sec. or less..the same stuff I use on wood joints when I don't want the glue to show and I don't want to wait for the glue to dry ..it's great stuff...
Any ideas?
sb
bobj3 is online now   Top - Reply with Quote
Old 09-24-2007, 10:00 PM   #3
challagan
Supreme Forum King
challagan's Avatar
challagan is on a distinguished road
I was going to suggest epoxy as well. With super glue if you use a clamp be sure you don't glue the clamp down. The accelerator works well and quick. Bj, for this application don't you think thin CA would work better? Just wondering.
I don't want to steer Steve's post another way but on the subject of gluing joints..are you talking about box joints and stuff with thick CA glue? Box maker Rob Cosman uses nothing but thin CA on his boxes. He soaks it on the ends of the assembled joints on the box. I tried it on a tight fit joint and no leak thru but it requires a lot of sanding cause the glue still ghosts thru the finish. Do you put it on the joints prior to assembly and then fit the joint together?
http://iowacarver.tripod.com/
My Shop Website - Woodshop 51503
http://woodshop51503.tripod.com/
challagan is offline   Top - Reply with Quote
Old 09-24-2007, 10:25 PM   #4
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Not to sure what CA is ?
I was going to suggest some 3M #77 spray glue because it's just a small gap to get into it, liitle masking tape on the edges and give it a shot in the crack then tape it down for a bit...
Old 09-25-2007, 07:29 AM   #5
AxlMyk
Forum King
AxlMyk's Avatar
AxlMyk will become famous soon enoughAxlMyk will become famous soon enough
When I was building radio control boats I would use thin superglue (CA) on the wood joints first, then the thick stuff to fill the gaps.. The thin soaked into the wood before I spritzed it with the accelerator..
For the laminate, I think I would use an epoxy.. Spread it in with a thin stick and clamp it down..
AxlMyk is online now   Top - Reply with Quote
Old 09-25-2007, 08:01 AM   #6
challagan
Supreme Forum King
challagan's Avatar
Bob, Cyanoacrylate = CA
Old 09-25-2007, 08:06 AM   #7
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Thanks Corey
I can see why they call it CA,, and I'm glad you can spell that
Old 09-25-2007, 08:16 PM   #8
challagan
Supreme Forum King
challagan's Avatar
Thanks Corey
You know that I cut and pasted it ha ha....
Old 09-29-2007, 12:05 PM   #9
Senior Moderator
Supreme Forum King
Mike has disabled reputation
CA, cyanoacrylic is the actual name for Super Glue or it's many other brand names.
laminate counter top lyoncub Starting Off 2 01-10-2008 10:57 PM
Pattern Glue BernieW Wood Scrolling 13 02-15-2007 01:52 PM
Glue advice Router is still my name Tools and Woodworking 17 10-08-2006 10:18 AM
Glue berry The Finishing Touch 3 01-21-2006 10:46 AM
