Thread Tools Display Modes
Old 10-07-2007, 01:15 PM   #1
hitnailonhead
Member
hitnailonhead is on a distinguished road
Question Need help with Rockler Aluminum table plate
I just bought the Craftsman Fixed plunge combo #17543. Anyone know which Rockler 1/4 inch aluminum plate I should order.They offer two.#23123 Standard Craftsman plunge/HD and #23134 Craftsman Plunge/HD I have an old Craftsman 1 1/2 hp #315.17492 fixed base and the newer Craftsman Professional 2 HP variable speed modle# 315.269211 All the base plates for all thes routers are the same pattern. Thanks for any and all help!!!!!!!!!
hitnailonhead is offline   Top - Reply with Quote
Old 10-07-2007, 01:42 PM   #2
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi hitnailonheadwithhammmer
The one you will need to order is the 23134 BUT for the 17543 it will also take on the Porter Cable base plates that's to say the base on the router is drill and taped for the Porter Cable setup as well.
And your New Craftsman router #17543 will also take the new Porter Cable motor...as well..
23123 Router Table Plate for Craftsman Standard Routers In Stock $49.99
23134 Router Table Plate for Craftsman Plunge and Heavy Duty Routers $49.99
http://www.rockler.com/product.cfm?p...5&filter=23134
Bj
Old 10-07-2007, 01:57 PM   #3
hitnailonhead
Member
Thanks for the quick reply.I just got the table setup Rockler had on sale for $299.00 Itt came with the PC 690 My problem is that I want to use the Craftsman because I can adjust it from above the table but the bolt up pattern is different.I had thought about just drilling a new set of holes for the Craftsman router but dont want to mess this plate up.
Old 10-07-2007, 02:07 PM   #4
hitnailonhead
Member
Sorry I should have said the PC 690 router
Old 10-07-2007, 02:41 PM   #5
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi
It's hard to mess this plate up, you have the template,,
take of the black plate of the router, tape it to the plate and check 3 or 4 times b/4 you dill the holes, use the holes in the plate for the drill size,,,take it the drill press or sit it on some scrap wood and drill and couter sink the holes...easy on the couter sink holes you want them just right...they line it up..
If you want to go the extra step make a plug that will fit in the hole in the base plate,drill a 1/4" hole in the plug, use that to line up the router dead on center.
Chuck up a 1/4" dowel pin or a true 1/4 bolt with out the head on it..
The take some screws that are the same size as the ones that hold the router plate in place, grind the heads off to a shape point put the screws in the router base ,set the router in place and with a small mammer, TAP the base,,,this will give you a point to drill the holes.. (they will act like a center punch but will mark all 3 holes at one time.)
Bj
Old 10-11-2007, 11:29 AM   #6
hitnailonhead
Member
Default Got wrong plate
If you have a Craftsman 17543 router get the small plate #23123 Not the 23134
Also the PC 690 and the Craftsman 17543 are not at all drilled and taped the same and the plates wont match!!!!!!!!!!!!
Old 10-11-2007, 06:36 PM   #7
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Sorry my error I was thinking of the MilesCraft base plate that will bolt right up to the PC and the Craftsman...
Bj
Old 10-11-2007, 06:47 PM   #8
hitnailonhead
Member
Wink Thats funny!!!!!!!!!!!!!!!
Guess I will start my project next week sometime.Win some lose some.Anyway thanks for trying to help
Old 11-24-2007, 12:30 PM   #9
osnomad
New Member
osnomad is on a distinguished road
Can you tell me what the bolt pattern looks like on this router plate? Does it have 3 holes or 4 unevenly spaced holes?
osnomad is offline   Top - Reply with Quote
Using a Rockler Router Table ArtShapiro Table-mounted Routing 9 12-15-2007 02:53 AM
Insert Plate size and 11.5" handle spread; how to prevent problems Ladd Table-mounted Routing 34 12-14-2007 01:08 PM
Bosch Router Table Plate Pattern Rhino Starting Off 2 11-24-2007 07:35 PM
Milwaukee 5615 Aluminum Table Plate Help pottsgo Table-mounted Routing 5 01-19-2007 12:02 AM
KM12VC is odd-sized for Rockler table? badpacket General Routing 4 02-01-2006 09:52 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109
