| | #11 |
| Registered User New Member | No, the fence was not on the wrong side of the bit, and of course direction of feed was correct. I had made the across grain pass and was half way into the with grain pass when the motor, with the bit still in the chuck dropped down into the table (out of the base) and then all (&*^%&%$) broke loose. It would appear that the base cracked and let go of the motor. Hard to tell now. Anyone that knows me, knows that I am pretty anal retentive when it comes to being safe and double checking everything, as I did on this occassion. All in all, I think it could have been much worse. The router went away from me, and not toward me. |
| | #12 |
| Forum Contributer Supreme Forum King | Hi Kward I'm glad you are OK ![]() But if I was the PC tech looking the base I would say user error,, forgot to clamp it down tight,,,It looks like a PC 600 type, that screw into the base...on a pin or two. But the base can crack ![]() But that's just my 2 cents ![]() BUT aging I'm glad your OK.... ==============
__________________ Router Tables plans FREE, plus more http://www.absolutelyfreeplans.com/W...p_projects.htm Router Tip Archive http://www.routerworkshop.com/router_tip_glossary.html Calculators http://www.routerforums.com/dynamic-calculators/ Last edited by bobj3; 10-09-2007 at 06:06 PM. |
| | #13 | |
| Retired Moderator Supreme Forum King | Quote:
corey
__________________ My Carving Website: The Iowa Woodcarver http://iowacarver.tripod.com/ My Shop Website - Woodshop 51503 http://woodshop51503.tripod.com/ | |
| | #14 |
| Forum Moderator Supreme Forum King | Wow glad you are okay. Always a good idea to take the bases out of table and do inspections on them to check for hair line cracks especially where they tighten at. Just amazing how your poly carbon plate cracked never saw one of that thickness.
__________________ Glenmore Days without wood working are days not worth getting up for. |
| | #15 |
| Registered User New Member | Porter Cable called, they are sending a new router! Wow! |
| | #16 |
| Marine Engineer Forum King | That's awesome! Although probably not the preferred way to get a new router....
| | #17 | |
| Banned Supreme Forum King | Quote:
Yes... WOW!! I've never seen anything like that before... thanks for showing. Just goes to show... y'a never know what can happen or when. Sure glad you weren't hurt!! Nice to see that PC will replace the router... Now, for a new Table Plate! ![]() | |
| A little accident | challagan | Shop Safety | 31 | 06-10-2007 11:36 AM |
| Drill safety | AxlMyk | Lobby | 5 | 04-13-2007 08:27 PM |
| Ouch! | Bob | Lobby | 8 | 10-26-2006 05:17 PM |
| OUCH! Bitten by the bad switch gremlin! | reikimaster | General Routing | 4 | 03-18-2006 02:50 PM |
