| | #11 | |
| Registered User Forum Geek | Quote:
'isolate the bearing' is woodie techie talk for Move the fence forward so the bearing isn't touched. And yes -- making shallow cuts is important for several reasons. Including but not limited to - less 'grabbing' on the wood and smoother final cut. As to whether to do this by raising the router a little at a time or by moving the fence -- that would depend on your preferences and setup. With my setup it is MUCH easier to adjust the fence than the router depth.
__________________ The one who says it can't be done -- Should avoid interrupting the person doing it. | |
| | #12 |
| Registered User New Member | excellent, now if i am going to isolate the bearing, would it be better to just remove it for the time being?, and then just carefully measure the distance between the bit and fence. Many of the router cuts will be exactly the same, so I could carefully set it once, and then make a large run. thanx scroll and wolf |
| | #13 |
| Registered User New Member | thanx drugstore, I will make maybe 3 or 4 runs moving closer each time. I think this will definately be easier than adjusting the router. |
| Cnc advice needed | mderzio | CNC Routing | 5 | 04-09-2008 07:32 AM |
| need advice for inserting rosseau router plate into bench dog promax cast iron table | sf_basilix | Table-mounted Routing | 7 | 02-21-2008 06:00 PM |
| Advice sought on router options | jcarter137 | Introductions | 2 | 02-02-2008 08:57 PM |
| Seeking advice - safety and feasibility | trex021 | Shop Safety | 5 | 04-09-2007 03:45 PM |
| Some advice before going to see the Dr. | Joe Lyddon | Lobby | 1 | 02-13-2007 08:18 PM |
