Thread Tools Display Modes
Old 10-23-2007, 09:51 PM   #1
jimcrockett
Member
jimcrockett is on a distinguished road
Default Garage Door Joinery
The bottom rail on my wooden 4-panel garage door needs to be replaced. It is worn badly and is incorrectly installed so that water seeps down the outside, under the bottom, and inside. Image #1 shows the garage door bottom rail and #2 shows the rail-stile joint that I need to produce.
It appears to me that the joinery is similar to a round-over rail and stile door router bit set. However, the bottom door rail and the stiles are 1-1/8" thick so I need to figure out how to make the tenon thicker and longer.
I saw a router bit on infinity's website, called an "Extended Tenon Cutter", but it is only available in ogee and shaker styles. This makes a 7/16" thick tenon as long as you want it to be.
My thought is that with 1-1/8" stock, I would probably want the tenon to be 1/2" thick and at least 1-1/2" long.
Does anyone have any thoughts on how I could accomplish this? I suppose if all else failed, I could route a mortise and tenon and then glue on some quarter-round molding but that really wouldn't do anything for the rail and stile joints.
Thanks in advance for any help you can provide.
JimC
garage-door-joinery-g-door-outside-r-bottom-corner.jpg  garage-door-joinery-g-door-bottom-edge.jpg
jimcrockett is offline   Top - Reply with Quote
Old 11-02-2007, 06:02 PM   #2
Hamlin
Supreme Forum King
A bull nose or round over should give you the best results for a rounded tenon. If that is what you're trying to do.
Ken
"A VETERAN"
"Wether active duty, retired, national guard or reserve - is someone who, at one point in their life, wrote a blank check made payable to "The United States of America", for an amount of "up to and including my life". That is HONOR, and there are way too many people in this country who no longer understand it." -Author Unknown
Old 11-02-2007, 06:44 PM   #3
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Jim
They make router bit sets just for this type of job..
They are not cheap but if you take the door apart I'm almost sure you will see this type of joint ..see below....
You can dig a bit on the Net and find the set a bit cheaper..the KATANA brand is the higher end of MLCS router bits...If I recall the last time a looked for this set I found it for 75.00 dollars...Price Cutters I think...
but the key to keep the water out of this type of joint is to paint it to seal the joint and make it water tight..you can also use some silcone around the joint but not inside the joint...
KATANA 2 Piece Matched Rail and Stile Set For Entry Doors
http://www.amazon.com/KATANA-Piece-M...046398&sr=1-45
From eBay ,at about 50.oo bucks
http://cgi.ebay.com/BRAND-NEW-ENTRY-...QQcmdZViewItem
JimC
Bj
Old 11-02-2007, 07:04 PM   #4
curiousgeorge
Supreme Forum King
curiousgeorge's Avatar
curiousgeorge is on a distinguished road
Seems to me for the price of the Katana bit set you could almost buy a new door.
George
If you can't fix it with a hammer, you've got an electrical problem...
curiousgeorge is offline   Top - Reply with Quote
Old 11-02-2007, 07:59 PM   #5
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi george
Almost, one of the painted Steel/Alum. ones that don't rust
I replace my wooden one on my garage with one of the insulated white steel ones after I checked on the price of a wooden one.. the wood ones do sag in time. if I recall it was $345.oo bucks installed...and they took the old one with them...
Bj
Old 11-02-2007, 11:30 PM   #6
curiousgeorge
Supreme Forum King
I recently replaced one of my garage doors and installed it myself for less than $200. It's really a fairly simple job. One person can do it but it's a lot easier with two.
George
Old 11-02-2007, 11:49 PM   #7
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi george
You'er right they are easy to install ,the one I had replace was a 8' x 16' ,,along time ago I was a garage door installer for about 2 years, and we/I aways did it by myself the only thing I didn't care for to much I always got stuck with the new homes with all the drywall stacked up in the garage , it woiuld take me more time to move the drywall then it took to hang the door, and I didn't care for was winding up the spring over the door ,they can be a bit scarey sometimes and I always got stuck with that type...unlike the easy ones with cable and springs on the rails... I did most of them in the dark with just a flash light, it was a 2nd job for me after the normal one ...but good money...
Bj
Old 08-06-2008, 01:29 PM   #8
Paul Dyar
Paul Dyar is on a distinguished road
In the process of making 2. I used roundover bit and mitered the joints. (Time consuming) Used tendon jig to make tendons Used dado to cut grove in the rails. And will use rabbet bit for the panels and glass.
Paul Dyar is offline   Top - Reply with Quote
Old 08-06-2008, 08:56 PM   #9
Dr.Zook
Supreme Forum King
Dr.Zook's Avatar
Dr.Zook is on a distinguished road
Send a message via Skype™ to Dr.Zook
Welcome to the forums Paul.
Dave
the "Doctor"
Dr.Zook is offline   Top - Reply with Quote
Old 08-06-2008, 08:58 PM   #10
Al Killian
New Member
Al Killian is on a distinguished road
I have the same type of profile on my doors. First run the stock over a dado blade to make the groove. Then you can do the round over sides. Or if you really like spending money, buy the set and you will have it for doors if you ever need to make some. Your door is much newer then mine. Mine are from the ?, well not sure. Still have the square nuts.
Al Killian is offline   Top - Reply with Quote
New Garage rh111 Project Plans and How To 14 10-04-2007 08:48 AM
Level Garage floor lablover Tools and Woodworking 28 07-10-2007 06:45 AM
Garage doors mailee Show N' Tell 5 06-05-2007 09:27 PM
garage guy jerry smith Introductions 4 05-22-2007 04:38 PM
Finishing in cold garage ShaneB The Finishing Touch 7 02-25-2007 07:21 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109
