Rate This Thread - Opinions requested.
Thread Tools Display Modes
Old 10-28-2007, 09:13 AM   #1
dabeeler
New Member
dabeeler is on a distinguished road
Default Opinions requested
There are some deals available on a Freud FT2200E 3/14 HP Router making it just under $28 less than the Hitachi M12V2 from Amazon. The router would be mounted to a Bosch router table. Is the Hitachi that much better than the Freud for use with a table to justify the price difference? Thanks for the feedback in advance.
David
dabeeler is offline   Top - Reply with Quote
Old 10-28-2007, 09:23 AM   #2
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi David
Do you mean Hitachi M12V2 ?
If so
I have both and I like the Freud over the Hitachi I have both mounted in a router table....but the Freud can be pop out of the table and be used as a plunge router..the springs on the Hitachi have been removed...no need to do that on the Freud because it's so easy to move it up or down in the router table with the knob under the table top.
Bj
Old 10-28-2007, 09:56 AM   #3
dabeeler
New Member
Bobj3,
Thanks for the reply. I did mean Hitachi. I caught the error after posting and corrected it. Your comment on the Freud Knob is interesting. I have been thinking of also purchasing the Router Razer for above table adjustments but your comment sounds like it may be no big deal to adjust the hieght with the Freud from under the table. Do you find that to be the case thus not really making it worthwhile to spend the extra on the Razer?
I can get the Freud for $125 delivered if I pull the trigger on the purchase before the free shipping expires on the 31st. I don't have a 3 1/4 Hp router and this seemed to be a very good opportunity to get one at a good price.
David
Old 10-28-2007, 10:17 AM   #4
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi David
I have the Razer on the Hitachi and it's a great help on the router table, I got the router from Bob N. ( a forum member) and it was on the router when I got it and said OK I will use it.. I didn't think I would like it but I do alot it's bit high in price ( 80.00 bucks for some rods and nuts) I didn't think I would put out 80 bucks for it b/4 I had one but if it went down I would put the money out to replace it,, it works very well with one little crank you can move the router up or down quick...so many times you just need to move the bit up or down just a small bit and it works great for that job..with out the need to get the router out of the table or to get on your knees and play with the router under the table top...BUT the draw back it's a router just for the router table.
I would say you don't need to remove the springs from the router and it will work just fine..
BUT if you want to remove the springs here's a link to help with that job.
http://www.routerworkshop.com/mark1.html
Originally Posted by dabeeler
Bobj3,
David
Bj
Old 10-29-2007, 02:19 PM   #5
jjciesla
Forum Geek
jjciesla's Avatar
jjciesla is on a distinguished road
Send a message via MSN to jjciesla
It seems to me that removing & replaceing the springs would be troublesome if you needed to do it often. Or am I missing something here?
Jim
jjciesla is offline   Top - Reply with Quote
Old 10-29-2007, 02:35 PM   #6
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Jim
Once they have been removed that's it the norm...now they go into a plastic bag and back in the box the router came in for safe keeping..
You only do it once, they are removed so you can move the router easy when the router is upside down in the router table, all you need to do is lift the weight of the router and not fight the springs at the same time
Or if you lift the router out of the table with the base place still bolted to the router you can move it easy to change out the bits...and preset the height of the bit..then just drop it back into the router table..
Bj
Old 10-29-2007, 05:31 PM   #7
Drugstore Cowboy
Forum Geek
Drugstore Cowboy's Avatar
Drugstore Cowboy is on a distinguished road
You finally hit on something - that would make me lean toward -getting a plate vs just mounting router to the table like I always have.
I have never had any problems changing bits with the router in place -- and reaching under the table to adjust depth is not that big a deal ---
But thinking about the way I like to work -- being able to set the depth with the router on its side rather than having to lean down and look across the table --
That has its appeal.
I was going to have to redrill my table for my new Craftsman ---
Thinking I may finally spring for a plate instead.
Sorry for the interruption---
I return you know to your regularly scheduled program already in progress -
The one who says it can't be done --
Should avoid interrupting
the person doing it.
Drugstore Cowboy is offline   Top - Reply with Quote
Old 10-29-2007, 08:16 PM   #8
Joe Lyddon
Banned
Supreme Forum King
Joe Lyddon's Avatar
Joe Lyddon is on a distinguished road
Welcome Aboard!
Joe Lyddon is offline   Top - Reply with Quote
New Pics, Need Opinions alienware Woodturning and Lathes 9 05-23-2008 11:57 PM
Forstner Bit Opinions jjciesla Tools and Woodworking 11 01-26-2008 12:24 PM
Opinions on the Drill Doctor Scotty Tool Reviews 10 01-16-2007 11:09 AM
Opinions on the Osborne mitre gauge Scotty Tool Reviews 0 01-14-2007 03:52 PM
Lathe Opinions nzgeordie Woodturning and Lathes 3 12-23-2006 01:46 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108
