| Table-mounted Routing Discussions solely based on operations that are using the table-mounted router. Bob and Rick say "More than 90% of all operations using the router can be done with the table-mounted router. |
| | #1 |
| Registered User New Member | what is easiest and best way to make double rabitt joints using a router table mounted router |
| | #2 |
| Retired Moderator Supreme Forum King | Hi roto, just chuck up a rabbet bit in the router with a fence, isolate the bearing so it isn't involved and set the fence out half the thickness of the stock and the height the bit to half the thickness of the stock and run them through. Corey
| | #3 | |
| Forum Contributer Supreme Forum King | Hi roto101 Just one more way ![]() T & G set of router bits. http://www.mlcswoodworking.com/shops...ue_groove.html http://cgi.ebay.com/2-pc-1-2-Shank-T...QQcmdZViewItem ========== Quote:
| | #4 |
| Registered User Forum Fanatic | Hi Roto - You have your answer from a couple of guys that know their stuff. But just so we're sure we are talking about the same thing, a double-rabbet joint is one in which both boards to be joined receives a rabbet. If both boards to be joined are exactly the same thickness, this type of joint can be faster and easier to produce since the rabbet is a consistant depth, and every board receives an identical rabbet. This type of joint resembles a shiplap joint, but with the length of the rabbet being exactly 1/2 the stock's thickness. If you are joining pieces end-to-end, or cutting cross grain, be sure to back of the end of your cut with scrap to avoid tear-out. Visualize removing a square that is 1/2 the thickness of the board. If there is a front and back to your boards, ... Think! I have done one or two on the wrong side and it really made me mad at me. Welcome to the Forum... there are some really helpful folks here with a wealth of information. Browse the topics and come back often. Don't hesitate to ask questions. ![]() Roger (Roefa)
__________________ Thinking outside the box? What box? |
| | #5 |
| Forum Contributer Supreme Forum King | Hi Just more ship lap joints,, see below =======
| Incra Ultra How-To (Box Joints + Other Stuff) | Nickbee | Show N' Tell | 5 | 01-21-2008 09:14 AM |
| Best bit for tight fitting box joints? | Nickbee | Router Bits - Types and Usage | 9 | 12-31-2007 01:13 AM |
| double rabitt joints | roto101 | General Routing | 1 | 11-18-2007 08:47 PM |
| Box Joints | reible | General Routing | 4 | 05-03-2006 10:44 AM |
| Drawer joints - Box vs. Dovetail vs. ??? | ChevyNomad | General Routing | 2 | 01-14-2005 11:20 AM |
