Help
Which hole pattern should I get (plate for a Bosch 1617)?
This is a discussion on Which hole pattern should I get (plate for a Bosch 1617)? within the Table-mounted Routing forums, part of the Routers category; Ok, after contemplating lots of different options I’m going to buy a pre-drilled plate and ...
Old 11-20-2007, 03:31 PM   #1 (permalink)
Nickbee's Avatar
Nickbee is on a distinguished road
Default Which hole pattern should I get (plate for a Bosch 1617)?
Report Post Report This Post!
Ok, after contemplating lots of different options I’m going to buy a pre-drilled plate and routing template for my Bosch 1617. I also have the under table base on its way for it. I know that base has holes for the standard Bosch 4 hole pattern and the more popular 3 hole (PC 690 I believe).
So. If I have the option of getting a plate either drilled for the Bosch 4 hole or PC 3 hole which one should I get?
I think 4 screws are better than 3. But then again the PC 3 hole would give me more options in the future.
Should I just flip a coin?
Thanks guys!
Nickbee is offline
Old 11-23-2007, 06:49 PM   #2 (permalink)
Birdflu is on a distinguished road
Been there - done that- which plate is best? I purchased the Oakpark Universal Plate which fits the Bosch, Craftsman and others. The universal plate allows you to mount several different routers using one plate. Check out their selection, I am sure you will be happy.
Using a plate for one specific router limits your future choices. Three holes vs four holes are not an issue at all when mounting a router. Two holes (if they exist) is another question.
I hope you find the suggestion useful.
Birdflu is offline
Mixing Bosch 1617 Router fixed base with Craftsman professional router sf_basilix Starting Off 10 10-24-2009 05:34 PM
Bosch 1617 screw hole template bigroccrek Table-mounted Routing 4 04-11-2008 09:37 AM
Bosch 1617 Router jimcrockett General Routing 3 03-24-2008 12:43 PM
Bosch 1617 router base problem bill kay General Routing 4 01-09-2008 11:53 AM
Bosch Router Table Plate Pattern Rhino Starting Off 2 11-24-2007 07:35 PM
